Results 1 to 13 of 13
    Vector Coil on Small RFX?
    Did a search (briefly on google) to see if the X-fusion Vector Coil has been mounted up successfully on a small RFX frame? I couldn't find anything. I emailed X-fusion, and they thought it would NOT fit, which was surprising to hear as the big CCDB coil seems to fit. Can anyone point me in the right direction?
    Dave
    Reputation: airwreck's Avatar
    what year RFX?
    The older frames fit the reservoirs but they don't make vector coil in 7.5 x 2. The newer rfx's are a tighter fit, maybe the shock can be flipped.
    2008. I am surprised the giant CCDB will fit but the vector won't.
    I am surprised no one is running this set-up. Only one way to find out then...
    No one at all? I know a few guys out there are running the HLR air from other threads, but they don't mention their frame size. Anyone running it on a small frame? It looks like the reservoir is roughly the same length as the coil. Anyone know for sure? I guess I may be looking at the chubie instead.
    I fitted a DHX 5 coil on my small RFX before. If you can compare the specs to the Xfusion shock, you may get a rough estimate if it fits.
    Thanks! The reservoir never kissed the down tube?
    Nope. Never kissed it on my small RFX.
    On my DW Spot, I had to take out the blue bottom out knob so nothing would hit.
    Anyone know of a vendor that would sell me a vector coil to mount up and see if it fits and return if it doesn't? I tried bikeco but it is a special order item so they can't take it back on return unfortunately.
    No one?
    Yay! Bikes !
    Reputation: Nick.'s Avatar
    I did email them. They said to talk to Turner regarding fitment. Turner said they would not be able to tell if it would mount up, and to try and get a hold of one to see if it fits. Bikeco said they wouldn't take one back on return...so still looking for other vendors. I did email X-fusion but they are so swamped with orders it takes them a bit to get back. Thought I'd try here while waiting.
    Reputation: beefmagic's Avatar
    Try Go-Ride. Not sure if they still do this, but they had shock trials for $50. You can put it towards the final cost if you decide to keep it.
  1. X-Fusion Vector HLR coil - Can a shock be too good?
    By derby in forum Shocks and Suspension
    Last Post: 09-14-2016, 07:42 AM
  2. Replies: 21
    Last Post: 07-11-2012, 01:38 AM
  3. X-Fusion Vector HLR Coil
    By tacubaya in forum Downhill - Freeride
    Last Post: 01-05-2012, 02:50 PM
