Results 1 to 2 of 2
    Turner Sultan - DW Link / Coil Shock Set up questions
    So I picked up an Avy Chubie and installed it on a 09 Sultan. It fits just fine. I was curious if anyone has any input on where I should start in terms of set up with rebound and compression.
    Thanks In Advance!
    Reputation: nybike1971's Avatar
    Quote Originally Posted by Luther View Post
    Thanks In Advance!
    If you bought the shock on the used market, you should start by making sure that the Chubie is valved for the Sultan's linkage. If the shock was used on a TNT bike previously or if the spring rate was very different from what you run, the external adjustors will not be too useful. Craig at Avalanche keeps careful files for each unit so he would be able to tell you if your shock would benefit from a revalve.
  1. Replies: 0
    Last Post: 07-05-2013, 01:39 PM
  2. Coil rear shock for 04 Specialized FSR, too fat for a RL + BETD link.
    By Schwazilla in forum Clydesdales/Tall Riders
    Last Post: 04-24-2013, 11:19 AM
  3. Turner DW Sultan Mod?
    By jncarpenter in forum Fat bikes
    Last Post: 10-15-2012, 04:14 PM
  4. My Turner Sultan
    By doublezero in forum Turner
    Last Post: 05-23-2012, 06:41 AM
  5. Turner 5 spot with coil shock
    By www.tizianophoto.com in forum Turner
    Last Post: 04-01-2011, 05:53 PM
