Results 1 to 3 of 3
    Turner Rebuild Kit Instructions for a DW 5 Spot
    Hi,
    I have just ordered a DW link rebuild kit, and waiting for the main pivot kit to restock before ordering.
    I was wondering, are there instructions with the kits? If not, does anybody know where I can get some please?
    E.g When do I add the grease, at the end? Do I grease the outside of bushings? How do I work the grease all the way in?
    Also, are there any tricks?
    Thanks Neil
    Just rebuilt my main pivot 2 weeks ago caused by a vertical play. To remove the bushings, I used ascrew drvier and gently tapped it from the other side with a rubber hammer. When putting them back in, do not apply grease on the bushings outside body (the one that touhes the frame) as it may encourage the bushing to turn overtime. Remember, it is the shaft's duty to turn, not the bushings. Its stiff I know but just to be sure. It has been stated also in the pdf manual. Check the site.
    Thank you. Found the instructions in PDF :-) bit out of date, but nothing has really changed :-)
