Results 1 to 5 of 5
    Turner Grease Gun
    Anybody know if the Manitou mini grease gun works for the fittings on Turner frames and if not what type does and where I can get one? Thanks Much
    Reputation: prooperator's Avatar
    yes but!
    The manitou gun will work, but it is difficult to use for the fitting at the bottom bracket. Turner has one available on their website. Order you one and you will not curse when trying to grease your ride.
    Official Member
    Reputation: morgan1819's Avatar
    Dec 2004
    I have an extra .. I pm'd you.
    Huh?
    What do you mean?
    Check your private messages . . .
    "p.m." They are located under the 'Welcome, Oceanfissure'. Click on 'Private Messages': Unread 1,
    I think that you should buy the Turner grease gun, because it makes it a lot faster to grease the ports using the bent end Turner grease fitting.
    Cheers,
    Kane
