Results 1 to 37 of 37
    Turner 5 Spot test ride
    Rode a large 5 Spot (correct size as 5'10") as a test bike found it a bit steep at front end and too short (front centre) so despite having a great rear suspension the front is not slack or long enough, anyone else found this? The bike should really rip with a 140 mm front end but feels a little perched when pointing down hill, somewhat ruining its great potential, for £2k for a frame in the UK, just not cutting the mustard.
    MK_
    MK_ is offline
    carpe mañana
    Reputation: MK_'s Avatar
    Quote Originally Posted by dogvet
    Sounds like you'd be one of the guys who runs a 160mm fork on the front. I agree that it's a tad short. DT addressed this issue before; from his perspective when he makes the frames longer, people complain it's too long, if he makes them shorter, people complain it's too short; apparently less people complain about them being too short than too long so he kept them short.
    There's also a group who prefers shorter wheelbases; 5spot keeps getting slacker so the front wheel gets pushed out; DW rear end is also a little longer than the previous generation so the TT shrunk to compensate.
    _MK
    Before you diagnose yourself with depression or low self-esteem, first make sure that you are not just surrounded by a*holes
    ride better, ride faster
    Reputation: inzane's Avatar
    I find the fit of my 5 Spot great... but then I have relatively long legs and a short body so the design probably suits me well!
    Reputation: Mr Pink's Avatar
    I found the test bikes i rode with 140 forks to be a bit steep so i went with a 150 float and no problem I prefer the shorter tt on the medium + standover Still a few frames going at £1500.
    Reputation: inkpad's Avatar
    Your fork choice is not cutting the mustard. Go with a minimum of 150, a u-turn 160 even better if you are consistently riding aggressive terrain. I have a 2010 Rev 150 dual air u-turn & the bike feels spot on, though I may go with a 2010 Lyrik soon, just because
    My cup runneth over
    Reputation: rmac's Avatar
    I'm with Inkpad on this too. I have the Vanilla RLC on my 2010 Spot and I keep waiting for it to 'break in' as it doesn't match the plushness of the rear. The Lyrik coil does look good but am waiting to see more ride reviews. FWIW, I don't want the Spot any lower but a tad slacker may just be the ticket.
    Reputation: Dibbs_'s Avatar
    Coil Lyrik on the front of mine, love it!
    Reputation: rgeniec's Avatar
    Feb 2007
    5'10" 175lbs. riding mine as a medium with 140mm float.
    had 160mm 36- too long
    got 150mm float and ended up reducing to 140mm
    run 75mm stem
    correct size is a medium according to the Turner site and the 5-spot geometry page.
    Did the shop put a shorter stem on it to make it fit?
    I already have a medium HL Spot and a medium HL Flux (which has longer TT than HL Spot). The Spot is too short a bike, the large is the correct size and the bike did have a short stem,
    Why should i have to put a big fork on to slacken slacken it out? The bike is designed round a 140 mm fork 525 mm A-C length, it is a little too steep a front end with its designated fork I feel, for a bike that has so much potential.
    I find the 5 spot is a bike that I sit in. Too slack and I find I struggle to get it up steep climbs. I've ridden plenty of bikes that feel more sit on. Neither is right or wrong.
    The 5 spot is a trail bike, if you want to make it slacker then you just put a longer fork. The ability to run a low front end helps with this also. I think Medium would be a better size for you so how you found it short I'll never know.
    I'm 5'9" with long arms and run a 70mm stem on a Medium.
    I am 5ft 10 as well and have a medium Flux. This seems to fit fine, as did the medium 5 spot I rode.
    I suppose it depends what you are looking for - to me the spot felt like a more 'traily' progression from the Flux, whereas you want something more DHR like maybe?
    Quote Originally Posted by AndrewDrummond
    I meant RFX...
    Its not the top tube length that is a particular issue it is front length, ie from BB to front axle that is quite short, that is why pointing the bike down hill seems less aggreable than some of its competitors with a slacker and longer front end.
    A smaller bike ie medium is ridable but body movement has to be more away from the c of g of the bike, balance and weight distribution between the tyres is not as constant and therfore less grip.
    May be its a UK thing
    Or maybe the focus of the bike is a compromise between having to ride up the hills in the first place before going down them - which is most trail centres in the UK I think.
    Reputation: wilks's Avatar
    A 23.6" top tube is extremely short for a Large. 5' 10" is the tweener height. I would always vote for the larger size with a shorter stem and so would DT - call him and he would say for dogvet to get the large. As for the fork I have posted a bajillion times that I think the 36 spaced down to 150mm offers a nice blend of climbing and descending. At the very least I would want a 150mm fork on a DW spot. I think part of the reason is that it sits higher in it's travel and the rear doesn't squat - giving you a steeper feeling when pointed downhill. I do think DT should have the standartd head angle be 68 degrees on a Spot with 140mm fork but for now it's 69.
    Quote Originally Posted by Bo Diddley
    I agree.
    I have the answer...
    run a 29er wheel on the front and a 26 on the back?
    Perfect example
    the variety of rider to frame relationships and frame, fork and stem combos in this very short thread is a perfect example of how there is no right or wrong in the current 5 Spot. There are people that have worked or currently work for Turner Bikes that agree with everyone of you. Look at the 5 Spot set up thread, all over the map, just like where we all live. If it don't work, fine. But nothing can work for everyone perfectly, that has been proven.
    Dogvet at 5'10 should be on a large with shorter stem, and no spacers and a low bar. The new for 2009 Large is perfect 'tweener size for guys your height. The bike works fine with a 140 or 150 or a 160, and some demand a 140 'cause they want that front end tight feel. More steer and less lean type riding or want the front end to stick like glue on a climb, or the 160 crowd wanting a different feel.
    DT
    Quote Originally Posted by turnerbikes
    DT
    DT on your site it says 5'11-6'1 for a large,at 5'10 with a 90mm stem on my medium it feels spot on
    I'm 5'11 on a large, 50mm stem, low sunline V1's. I run my Lyrik pretty much at full travel for everything - including some prolonged climbing in the Alps. And thanks to the anti-squat the back end doesn't hunker down making the front end even lighter. For years I've been a tweener but now I have the perfect fitting bike. But I understand that will now alienate other sized people - tough sh*t!!
    If it doesn't fit you or you don't like the characteristics then move on, it doesn't mean the product is wrong.
    It's a trail bike at the end of the day, but it just happens to be stiff enough and strong enough for people to stick longer forks on.
    Mine is a joy to ride downhill, especially all day in the Alps.
    Maybe your technique sucks :P
    MK_
    MK_ is offline
    carpe mañana
    DT, what about an idea of alternating TTs between model years so half get their fill on odd years and the other on even years?
    _MK
    Reputation: JonnySpitz's Avatar
    Not to knock the shop you were at, but many of the demo bikes I have ridden (Spot included) had the suspension set up all wrong for me. The Spot took me a bit to figure out and I ended up with more air in my fork than I run on other bikes to prevent it from diving with the rear suspension set up properly. I have heard others say the same, so I don't think I'm a complete idiot. Maybe that's what you were experiencing.
    Once I set up my fork properly and got a feel for the bike, it just wanted to fly over everything.
    Great idea,
    MK! I will pass though, hope you forgive me.
    Jonny has a good point as well. If the wrench setting it up is off , the ride is trash. many think that 'body weight' in the rear shock is fine and some random amount in the fork, especially some forks that seem to never get full travel, so they are under sprung in pursuit of full or close to full travel creating a mess on the trail.
    DT
    Rear and front shocks were set up correctly, prob been riding suspension bikes as long as DT so gleaned little bit over the years, so have a fair idea of what goes on.
    Prob rode in Alps Dibbs at a time you were having your nappy changed by your Mum.
    Are you saying you are past it then?
    Seriously, if the bike doesn't work for you then move on. But it works for plenty others as we're all different sizes and like different characteristics in a bike. Really not sure what the point is you're getting at other than you like a bike long and slacked out loads. Which is really interesting but if the 5 spot what like how you obviously want it then I wouldn't be riding one.
    And what's UK got to do with it?
    Perhaps Trail dog when you are as fit and lean as I am at 54 you come and talk to me about it, I leave plenty of my younger contemporaries for dead on climbs and descents.
    Besides my view was not necessarily a criticism just an observation of how I felt the bike rode and wondered if anyone felt same , which a few do.
    I dont feel that any comments as to ones bike skills or otherwise is of any value or relevance to what was originally posted.
    But it would appear like many of your type your arguements/discussions are always personalised.
    I would like thank DT for suggesting the correct size as I concur. The contact points on the demo Spot were spot on. I ride a 140 travel trail bike as he described, 50 mm stem wide low bars and no spacers, so far from being past it, I 'm probably ahead of the curve!
    Reputation: zonoskar's Avatar
    I have to question this as some people on the 5Spot take weeks to get the correct suspension settings. Just because the sag was set at the preferred setting doesn't mean the suspension is setup right for you. Some run 14mm sag, some run 17mm, and some run more. I think DT advises to run 14-17mm sag. I found that the 5Spot is extremely sensitive to rear suspension setup, much more so then TNT or HL equipped bikes. I also would advise to run at least 150mm forks on the 5Spot. With 140mm the HA is way too steep.
    Deary me...
    It was a joke, hence the " :P "
    But do carry on telling us how much better you are than everyone
    No Dibbs will leave that to people like you.
    I don't believe I wrote anywhere about nailing people up and down hills and being soooo far ahead of the curve
    Your sensitive little soul is obviously too delicate for a public forum. I'll add a wink this time so you don't throw a hissy fit.
    Man, chill out. I said I wasn't being serious. Talk about being sensitive.
    You're view is valid in so much that you don't like the bike, but you didn't actually say that. You said that it's not cutting the mustard for a 2k frame in the uk. Which isn't true, as many people love the handling of them and they generally last a long time and work brilliantly in UK conditions. So people are going to question you as your statement isn't correct.
    So quit getting so over sensitive when you obviously trying to square up for a fight, or at least create a bit of a stir.
    Moosehead
    Reputation: moosehead's Avatar
    <embed src="http://www.metacafe.com/fplayer/1068467/cabin_fever_pancakes.swf" width="400" height="345" wmode="transparent" pluginspage="http://www.macromedia.com/go/getflashplayer" type="application/x-shockwave-flash" allowFullScreen="true" allowScriptAccess="always" name="Metacafe_1068467"> </embed><br><font size = 1><a href="http://www.metacafe.com/watch/1068467/cabin_fever_pancakes/">Cabin Fever- Pancakes!</a> - <a href="http://www.metacafe.com/">The funniest videos are a click away</a></font>
    Actually if you read the initial post I did not say I did not like the bike, but was more curious if any body else felt riding the bike with a 140 mm fork (for which the bike is designed) felt the front end a little steep. Zonoscar and DT acknowledge that in their postings, are you going to argue with the designer. He also corrected your assumptions about the correct size.
    Yep I have 2 Turners already if you read the previous post, so I do have some experience of the quality, customer care and longlevity, but hey thanks for the reminder.
    Are you experienced?
    <object width="480" height="385"><param name="movie" value="http://www.youtube.com/v/DDUe9BFPrzg&hl=en_US&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/DDUe9BFPrzg&hl=en_US&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385"></embed></object>
    Not sure how much time you spent on the dw spot but i had five rides on three bikes untill i made my mind up to change from my 08 spot.What made my mind up was when i rode one with a 150 float,i just would not use a fork with less travel now,with the 140 i got bucked over the bars twice
    I would give the bike a few more hours testing and play with the sag settings on the rear,try and get a shot with a 150+ fork
    Thanks for the constructive advice Mr Pink, rather than the personalised abuse! perhaps I should come up to the Lakes some time and ride on some of your local trails!
    Your welcome anytime,have you done any rides in the Lakes?
