Results 1 to 2 of 2
    jbf
    jbf is offline
    Reputation: jbf's Avatar
    TNT 5-Spot rear shock setup
    I am building up a 2008 TNT 5-Spot and looking for guidance on the initial rear shock setup. I have rebuilt the frame pivots using guidance from this forum and am ready to service the Fox RP23 HV before I build up the bike. Current shock was PUSH'ed for a 180 lb rider and has the large air can. I weigh 155 lbs and ride rough New England trails, which means I like a plush suspension and will be running a Marzocchi 44 RC3 coil up front.
    My question is: Should I consider installing the standard size air sleeve and/or the Fox volume tuning kit while I have the shock apart? I'd rather learn from other's experiance than tinker repetitively with the shock. Any thoughts from current or former TNT riders would be appreciated. Thanks ...
    Reputation: prooperator's Avatar
    With your weight I would go with the standard tune.
    Too wet to ride!
