    Tapered fork on 5spot ?
    I'm wandering if 5spot frames are compatible with this new head set.
    Cane Creek's new XX 44mm Traditional lower headset assemblies will let riders use tapered forks in frames equipped with a straight 44mm-bore 1-1/8in ZeroStack head tube
    http://www.bikeradar.com/news/articl...ad-tubes-25275
    Any one can answer to this?
    Flat out
    No - the 5.Spot's headtube is traditional 1 1/8 '', so the inner diameter is 34 mm.
    I don't think so. 5 Spot frames are not ZeroStack so I don't see how they could be compatible.
    Ok, sure, it would be too nice to be true...
