Results 1 to 45 of 45
    No, that's not phonetic
    Reputation: tscheezy's Avatar
    We the people ... Sultan rocker musings
    I've had 3 sets of rockers on my Sultan now: stock, 5.5 Spot, and Push Spot. They all deliver around 4" of travel on my Sultan. The rockers come from different bikes and produce different average leverage ratios on those bikes:
    • Sultan/Flux 2.67:1
    • 5.5 Spot 2.75:1
    • Push Spot 2.93:1
    I have measured each on the Sultan by flipping the bike over and resting it on the handlebars and saddle (my grips and saddle are level when the bike is right side up, so upside down the bike is still level), and measuring the vertical distance between the floor and the center of the rear wheel axle. I then totally deflate the shock and use a bar clamp to pull the rockers as far towards the seatpost clamp as I can force it until the shock is totally bottomed. Finally, I measure the distance from the floor to the middle of the rear wheel axle again and subtract it from the first measurement. The difference is the effective vertical travel of the rear wheel.
    In the case of the 5.5 Spot rockers I got 693mm minus 599mm giving me 94mm or 3.7" of vertical wheel movement. I did the Push Spot rockers a while back and got exactly 4" of travel. It's been a while, but iirc I got right around 4" with the stock Sultan rockers also. The Push Spot rockers are quite a bit longer in back, but also noticeably longer in front, of the rocking point than the stock Sultan rockers.
    The stock high compression tune RP23 is a pretty overdamped and sorta harsh feeling shock with the stock rockers. With the Push rockers the stock shock does feel better though, and seems to break free more smoothly at sag and offer a bit more action through mid-stroke. The rate curves the two rockers produce must be quite different to make the same shock's behavior feel unique in each case, and to have purportedly different average leverage ratios, and yet produce the exact same amount of absolute travel.
    Darren probably has this all mapped out and could explain it in terms I still wouldn't understand.
    My video techniques can be found in this thread.
    Time flies...
    Reputation: xjbebop's Avatar
    that's all well and good, but the 'bottom' line is:
    What does the seat of your pants tell you when riding?? Which ones just 'feel' better?
    ...every day sends future to past...
    Push Shock or Rockers.
    If the Push rockers allow the stock shock to perform more smoothly and a pushed shock may achieve the same, what would be the better choice if forced to pick one?
    Reputation: miles e's Avatar
    Quote Originally Posted by tscheezy
    Darren @ Push came up with these numbers:
    Stock: 4.04" of wheel travel
    w/5.5 Spot Rockers: 4.08" of travel
    w/PUSH Rockers: 4.19" of travel
    ''It seems like a bit of a trend, everyone trying to make things longer over the last couple of years" Sam Hill
    ... I guess you won't be
    Reputation: jokermtb's Avatar
    Unfortunately, T hasnít accounted for the humidity index of the air within the shock changing over the testing period, which would introduce a confounding variable to the damping properties observation from session to session Ė no way to quantify his results with this variable unaccounted for, therefore I have to consider T's thesis is invalid - for now.
    Please account for this variable, and resubmit.
    <o></o>
    Here's another tidbit I dug up from Darren where he talks about swapping the stock Sultan rockers with Push Spot rockers:
    Quote Originally Posted by PUSHIND
    - Direct replacement
    - No Geometry Change (BB, HA, etc.)
    - Travel increse of 0.125" (3mm)
    - 5% change in rise of rate (higher from 0.78"/20mm thru 3.1/80mm of wheel travel)
    I am wondering if when they "map" the travel they are measuring along the wheel arc unlike me who is just getting vertical displacement perpendicular to the ground. The wheel moves forward as well as up at the end of travel. Then again I have gotten Turner's published numbers to within a millimeter or two using my method so it has worked well in the past. I also found absolutely no difference in BB height between the Sultan and Push rockers, and only saw about a 1/16" drop moving to the 5.5 Turner rockers.
    rr
    rr is offline
    I don't do PC
    Reputation: rr's Avatar
    Quote Originally Posted by jokermtb
    <o></o>
    Good point, but I just want to know which setup he likes best so I can go out and buy that combo of shock/rocker and be one of the cool kids here
    Reputation: PUSHIND's Avatar
    Leverage
    Let me try on this one with a hypothetical:
    Rocker A
    @ 0.5" shock travel, leverage is 3.0/1
    @ 1.0" shock travel, leverage is 2.5/1
    @ 1.5" shock travel, leverage is 2.0/1
    High initial leverage which produces good small bump sensitivity with aggressive rising rate that allows for good mechanical bottoming control. This allows for you to run softer shock settings which aid in traction and bump sensitivity without compromising bottoming control.
    Rocker B
    @ 0.5" shock travel, leverage is 2.0/1
    @ 1.5" shock travel, leverage is 3.0/1
    Lower initial leverage, that falls in rate. This forces the rider to run higher pressures in order to keep the shock from blowing through its travel to easily. This results in difficulty getting good sag measurements as well as a resulting loss in initial small bump sensitivity.
    Using the rule of dividing the wheel travel by the shock stroke, you'd come up with an average rate of 2.5/1 with both bikes, as well as the same amount of travel. The reason I've always argued the "average" leverage rule of thumb is because you can see that the actual leverage of the two examples above would produce a radically different ride characteristic.
    Darren
    rr
    rr is offline
    I don't do PC
    Which example do the stock rockers resemble?
    Natl. Champ DH Poser/Hack
    Reputation: cactuscorn's Avatar
    i dunno darren. cheeseys tundra logic and frozen formulas have always been well recieved in the past. sure ya trust this scientific method of yers?
    im kiddin ya both. carry on.
    No, I'm NOT back!
    Alaska Turner Mafia
    Reputation: EndoRando's Avatar
    Sep 2004
    And here I go throwing another in the mix!
    Since I sent my 5.5's to ts to try out, I decided I'd try out a set of 5.3's on my Sultan. Of course I was running it with a coil shock last month with our still colder temps, but wanted to get an initial impression and ferret out any incompatibility issues. No issues so far.
    The notion I had was to see if the added length in front of the mid-rocker pivot would add some leverage to help overcome the high compression damping effects of the RP23, especially with these short stroke shocks. ts also has my air shock, so I'll wait and test for seat of the pants feel as well.
    Of course riding with my coil shock is apples to oranges compared to ts's riding time, but, my gut feel said the advantage to a non-stock rocker is not just the added leverage gained from the rocker's rear half length, but from the added front half of the rocker's length also. Both sets of travel measurements listed by ts and Darren show negligible differences, but change the leverage rates, so why not try the 5.3 as well? I bet I find the ride characteristic with it to be similar to the A scenario Darren mentioned. We'll see. I'll give it a run once ts has satisfied his curiosity. Good stuff.
    Darren, could you plunk in 5.3 numbers for results, or would they pretty much mirror the 5.5 and yours?
    Rando
    Deceleration Trauma is my middle name
    Quote Originally Posted by EndoRando
    I think he needs to physically have the bike in question in his hands and run it through its paces.
    One other oddity I have noticed is that your shock is about 1/8" longer in i2i than mine (yours measures 6.5 and mine is under). Mine isn't stuck down or anything, it just seems to be a little stumpy for some reason.
    Rando
    I ran the 5.3's for a while. I easily prefer the 5.5's to them tho.
    Reputation: nybike1971's Avatar
    • 5.5 Spot 2.75:1
    • Push Spot 2.93:1
    Tscheezy,
    The average leverage ratio you reported for those rockers is on different bikes with a linkage that is different from the Sultan. If you are correct and the total travel for given shock stroke is identical with two different rockers on the Sultan, the average leverage ratio of the linkage will be identical.
    Here is the setup I use to map out linkages:
    I can change the i2i distance a few mm at a time and measure the vertical displacement of the axle. I do not own a Sultan, and my measurements have been on a 5-pack and RFX with PUSH and 5.3in rockers. The main difference between the two I measured (other than the total amount of travel) is that the leverage ratio starts higher with the PUSH rockers and ends almost exactly at the same place as the 5.3in rockers. The 5.3in rockers have a very linear behavior throughout the shock stroke. Those results are summarized in this thread:
    06 RFX/5 pack leverage curves and geometry measurements
    Again, I am not claiming that these results hold exactly for the Sultan linkage, I am just sharing how those rockers affect suspension characteristics in a couple of other linkages.
    Just yesterday I received my 5.5in rockers, soon I'll measure the 5-pack linkage with these rockers and update the thread comparing all three 5in rocker options with a Spot rear triangle.
    Miles measured the total travel on his Sultan with a 1.75in stroke shock and reported his results in this thread (I am referencing the relevant posts):
    http://forums.mtbr.com/showthread.ph...48151#poststop
    http://forums.mtbr.com/showthread.ph...48523#poststop
    If someone wants to ship me a medium Sultan for a couple of weeks I'll be happy to map the linkage with all the rockers (for both a 1.5in and 1.75in stroke shocks) ...
    Quote Originally Posted by nybike1971
    Exactly. That's sorta why I opened this can of worms. It is hard to pull rockers off another bike and predict exactly what they will do on a different model that has most of the other pivots in different locations and runs a different stroke shock. The 2" stroke shocks on the Spots would cause the rockers intended for that bike to go through 25% more rotation than they would when mounted on the Sultan, so things would have to feel pretty different.
    As Darren has said, sometimes you just get lucky and it works out for the "better."
    Expert Crasher
    Reputation: GreenLightGo's Avatar
    what I take away from all this rocker arm talk is that, unless you have a reason to need a higher leverage ratio, all you need to do is stick with the stock Sultan rockers, and if the $$ is available or the need is there, tune the RP23 with a PUSH treatment.
    i.e. for the XC focused rider, the stock rockers are perfect
    Happiness depends more on the inward disposition of mind than on outward circumstances. Benjamin Franklin
    Quote Originally Posted by GreenLightGo
    I really disagree. I'm not necessarily sure with regard to Tscheezy's findings, becuz I am running a pre-production Sultan frame & I know the bb pivot was moved prior to production...that said: my bb height dropped nearly .5" from the stock rockers to the 5.5's. I also think that the 5.5 rockers have much better ramp up at the end of the stroke as well as handling g-outs. This allows me to run a bit less pressure & still not bottom out excessively. I have the 5.5/ 5.3 & stock rockers available (heck I even tried out the 08 rfx rockers ), but the ones I prefer most are the 5.5's. My $.02 & ymmv.
    Quote Originally Posted by jncarpenter
    This matches my experience with my production Sultan. I don't recall the exact change in BB height, but it sure seems like it was closer to .5" than 1/16"; 3/8" I wanna say. I'm pretty sure it was at 13.25" with F135, 5.5 rockers & RP23, then 13 5/8" with the longer CCDB on, which is about what it comes out to with a F135 and the stock shock/rockers.
    I only had one ride with the 5.5's and RP23 before the CCDB came in, but I remember being able to run the pressure ridiculously low (and I like a soft rear end ) w/o bottoming, as was also the case on a few rides I did with the 5.1's and RP23.
    The increased stiffness with the 5.5's was noticable too.
    Miles and JNC: I have no doubt that you guys are correct in your assessment. My questions for you are:
    1) Is there any fork/shock combination for which you would prefer the stock rockers?
    2) Why do you think DT specs the Sultan with the Sultan/Flux rockers instead of the 5.5in Spot rockers?
    3) Is there a downside to the 5.5in rockers on the Sultan?
    Umkay, I swapped back to the stock Sultan rockers and measured veeeery carefully. I got 335mm BB height with the 5.5 rockers and 338mm with the Sultan rockers, a 3mm difference, or under 1/8" if you don't like metric. That's with a White Bros F135 fork and WTB Stout 2.3s front and back.
    1) Set up for racing, with a Reba on front, the stock rockers are fine. The give a firmer feel but still allow for full travel. I'll be trying a Fox soon though, and wonder if I might prefer the geometry of the 5.5 rockers with it since the way they slacken the front end would help counter act the quicker steering (presumably) provided by the shorter fork and increased offset.
    2) I think it was probably a pretty easy decision to keep the same suspension design as the 4" travel 26" wheeld bike (Flux) for the 4" travel 29" wheeled bike. And of course DT designed the geometry from the ground up to work with those rockers, as opposed to our chop shop approach to customizing the geometry. Plus, I don't know if anyone (even DT) seriously thought the longer rockers would be compatible at all with the Sultan until JNC bolted on some 5.3's about a year ago. Now that it's pretty well established that they do work, and work well for many riders, I suppose it would be a nice factory option, although that might just confuse a lot of riders.
    3) They're ~1/4 lb. heavier, more expensive (aftermarket, and presumably for Turner too), and as with any geometry change (see the new RFX thread ), what works for some riders may be the opposite of what others want.
    Expert Crasher
    interesting, did not know about the ramp up at the end. I moved to the Sultan from a 5x5 26" bike that used a Rock Shox MC3.3 (which I quite liked) , it was plush initially with ramp up at the end, rode like a plush trail bike/light AM ride. Initially, I was a bit put off by the amount of 'feel' I was getting from the Sultan until I managed to dial in the RP23 to my liking. It's not as plush as my old ride but much more competent, I guess. I was looking for a bit more XC ride and only running 5 gears out back, I tend to like the stiffness now but do notice that I am using all the travel when I'm hammering the downhill sections of rooty trails here in AL. I don't physically feel a bottom out but I'm also conscious that it's not the pillowy smooth action, an almost detached feel, that my previous ride had. I have grown to like the feedback as I'm more aware of what the rear end is doing and can adjust body weight when necessary, it's actually helped me go faster. Side effect of Sultanism I guess - unexplainable gain in speed.
    That being said, this is only my second FS ride and it's hard to compare a 5x5 26" bike to a 4x4 29" bike - too many other variables. I'm so satisfied with the setup and performance of the Sultan for the type of riding I do and my riding style that I don't see changing anything in the near future, with the exception of PUSH'ing the shock when it's time for a service and adding one of those sexy new Reba 120s with a Maxle.
    One Q though - on my RP23, there is a small sticker with three graduated hash marks, the small hash mark on my sticker is white, the medium and long hash mark are gray - what is that indicating?
    There are usually some words printed next to that little bar graph you are referencing. It will say "compression tune" or "rebound tune" and it basically tells you what sort of background valving the shock has from the factory. You can twist knobs to change the shock's compression or rebound to some degree, but the general behavior is set at the factory. The tall bar being filled in with white means it has the highest amount of damping, the low bar indicates the least damping. In your case it may be the rebound as Turner spec'ed the rebound to have the lowest (fastest) tune and the compression to have the highest (firmest) tune. Some of the "firmness" you feel may be the constant background damping in the shock even when the propedal lever is flipped to the "off" position because of the high compression tune (if you have one of those shocks).
    Expert Crasher
    actually, it doesn't say compression or rebound anywhere, just "propedal tune" on the red/white opposing 'P' emblem. I'm running the rebound damping on 8, (with 1 being no damping, 10 being fully damped as I only had 10 clicks on the red rebound knob) so what you say about Turner's rebound specs makes sense.
    I think if the early shocks had a bar graph, it referred to compression.
    Homer's problem child
    Reputation: Bortis Yelltzen's Avatar
    The RP23 from my Sultan has been at Push for the last few weeks. I was pretty bummed on the compression tune on my RP23. Just felt over damped and harsh no matter where I set the PP, though I was using all my travel on every ride. I'm a big fella (215 lbs) and had already swapped the high volume can for the standard which seemed to help keep the shock from blowing through it's travel for me. I talked with a few Sultan owners and Squeaky (who from what I can tell has an office at Push ) and the majority of the feedback I got was tuning the damper has a much more pronounced effect on the ride than swapping rockers.
    So for less than $140 it seemed like Push was the logical thing to try first. If I'm still not feeling much of a difference with the Push tune then maybe I'll try some different rockers. And if that doesn't work........................look for a Sultan in the Classifieds and I'll get a Rip 9 or Lunch box or.......something with more travel because 4" isn't getting me the feel I'm after. I just want a better match to my WB F135, and my stock RP23 was not giving me that.
    How much $$ are 5.5 rockers approximately?
    I'll report back when my shock comes back and I get a few rides on it. SHould be here next week.
    B
    When the going gets weird, the weird turn pro....
    Expert Crasher
    ok - thanks. Shock is probably an 07 (as the frame is) b/c the air valve is still in the original spot, not the new 'improved' location on the 08s.
    Quote Originally Posted by Bortis Yelltzen
    I go 210
    I'll be looking forward to your feedback when PUSH is done with your shock - did you get the whole Factory tune
    Blasphemy - you'll have to pass me your PUSH'ed shock and spring for the CCDB before selling.
    B
    Well I got my RP23 back and put a few good rides on it. The Pushed RP23 is a substantial improvement over the stock RP23. Better small bump performance, better bottom out and just better more controlled travel throughout the stroke overall. Hit a nice 4-5' drop to tranny last night and it was smooth with no harsh bottom out. So far so good. Push's recommended air pressure was a bit high, couldn't even get 20% sag all geared up at their pressure so I adjusted pressure until I was between 35-30% sag, ended up being about 20-25 psi lower then what Push recommended. I'm running the standard can and maybe their pressure was for the large can, but I sent it in with the standard.
    Then I saw this thread:
    Want to Buy 5.5 Spot Rockers...
    and sprung for some 5.5 Rockers. Hopefully the Push mods won't be rendered to far out of line with the 5.5 rockers. I'll try it out and see what happens.
    B
    ...sprung for some 5.5 Rockers. Hopefully the Push mods won't be rendered to far out of line with the 5.5 rockers. I'll try it out and see what happens.
    B
    Actually, it is a night & day different setup. I have a feeling your small bump compliance will suffer a good bit.
    Care to elaborate a little?
    Thanks,
    B
    Thanks,
    B
    I'm not really sure what you're looking for beyond that. The suspension curve is dramatically different with the 5.5 rockers. As such, an equally different tune is required. In order to get the level of SBC for my setup, Darren had to essentially remove the function of the propedal (for all intents & purposes). You essentially end up with a curve that matches the last 4 inches of the 5.5 Spot.
    What is your reason for ordering them?
    Your posts about how great they are.
    Well, I have them coming now, so I'll be able to tinker, and if I have to send my RP23 back to Push then so be it. I can always swap back to the stock rockers. I would have ordered the 5.5 rockers prior to getting my RP23 Pushed but Turner was out of them and I couldn't find any through other sources.
    Thanks,
    B
    They stole your HV can?
    No, I swapped to the standard can and had been riding it that way before I sent it in. I like the way it ramps up at the end of stroke more than the HV can. I'm just assuming the pressure they recommended might be for a HV RP23 which most run on their Sultans. I'll probably swap cans a few times to see if I can tell any difference between them with the Push tune.
    Sorry for the confusion.
    B
    Bodhisattva
    Reputation: The Squeaky Wheel's Avatar
    I'm running the HV can on my Push tuned rp23 with 175 psi.
    I may try either the regular can or have Darren a bit of BO resistance because I occasionally hit bottom on g-outs.
    For me, the Push tune made much more of a difference than the Push rockers.
    Quote Originally Posted by The Squeaky Wheel
    Did you have your RP23 tuned to the stock or Push rockers? You may have already mentioned it but I'm too lazy to look it up.
    I sent Push an email asking their thoughts on it as well.
    Thanks,
    B
    rr
    rr is offline
    I don't do PC
    So in theory with the stock HV shock you would need more psi than the smaller can?
    I'm running 190psi(200lbs) w/stock HV can and rockers, sounds kinda low based on what others are running, not sure if this is due to diff shock/rocker combo's tho.
    I seem to get the right sag at 3/8" but def use all the travel on most rides
    Pixie Dust Addict
    Lemme know how that whole BO resistance thing works out Squeak. Like, can Darren do that kind of fine tuning on an RP23? I ride at about 195-200 lbs and have a HV can with the sag set at 3/8". I like the plushness, but I can definitely get it to bottom on g-outs and landings of 1'-2' to flat. I still need to try the PUSH'd RP3 (small air can) from my Flux to see how that feels.
    rr
    rr is offline
    I don't do PC
    Quote Originally Posted by 2TurnersNotEnough
    How much psi are you running?
    Bodhisattva
    Thanks,
    B
    I was the beta for the Sultan RP23 tuning +/- Push rockers and Darren had me try several different settings.
    Yes, my RP23 is now tuned specifically for the Push rockers. The suspension feels superb and the high speed g-out bottoming only occurs rarely. I've never hit bottom on drops up to 4 foot. I recall Darren telling me that the HV can with the Push rockers might lead to a bit too much through-travel and it wouldn't surprise me if guys heavier than my hefty 170 lbs might not be able to use the HV can with the longer travel rockers (Push or Spot rockers).
    I have 2 rides on the 5.5 Spot rockers with the Pushed RP23 and am sold on them. Even with a Push tune that is not optimized for the 5.5 rockers it rides more like what I want than with the stock rockers and Push tune. Feels like it has much deeper travel, more supple in the mid-stroke and deep in the travel, and just generally more like a trail bike than an XC racer. No bottom out issues and if there is a small bump compromise it is minor and still much better than stock. I run my PP in the off position with the dial at 1 anyway. I'll contact Push and see how much of a difference they think the tune needs to be with the 5.5 rockers, but for now I am really liking it much more than stock and stock/Push RP23. Interesting note is I am now running the shock pressure that Push recommended when I got my shock back. I was running about 210 psi with stock rockers and am up to 230 psi with the 5.5 rockers.
    Bottom line is I much prefer the 5.5 rockers. So much so that I think Turner should offer an AM spec with the 5.5 spot rockers and then an XC spec with standard rockers. So you can buy it straight from Turner with the 5.5 spot rockers.
    I am happy with this bike right now.
    B
    B
    Out of curiosity this weekend (after thinking it over per our discussion in this thread), I decided to slap the stock rockers on & try it with the PUSH tune. I found that if I had enough psi to keep from bottoming, the ride suffered a bit...if I lowered the psi to soften the ride some, I then bottomed excessively. Perhaps the LV can would have helped...but the best solution seems to be to put the 5.5's back on
    Yeah, at my weight (220-230 depending on whats in my pack) the HV can is not an option. I just bottom all the time with it.
    B
    Reputation: ccornacc's Avatar
    Anybody try RFX rockers on a sultan? Would they fit? What might the results be? Good or bad? More travel? Just wondering.
    I have Push rockers now and love them, but even a little more travel would be better.
    Bite Me.
    Reputation: cutthroat's Avatar
    My guess is that you would get tire to seat tube contact a full compression, but that's only a guess. The RFX rockers are only slightly longer than the 5.5s, but enough to add .3 to .4 inches of additional travel on the RFX 2.25" stroke shock compared to the 5.5s, so you would probably gain a little more travel but not a lot on the Sultan's 1.5" stroke.
    When I see an adult on a bicycle, I do not despair for the future of the human race. ~H.G. Wells
