I have an older (01?) Turner Stinger frame. The rear seatstay has a single threaded hole where I assume you'd install a disc brake adaptor. Any idea where I can find this adaptor?
i dont think thats a adapter mount point but i may be wrong. however, this may be of some help. as far as i know, the stinger, like early burners, were not designed around disc brakes. this does not nessesaraly mean one cant be safely mounted. ive done so on a '96 burner with outstanding results. can you do the same with a stinger? dunno. all depends on tube structure and theres one man who can say yes or no. ask david turner dt@turnerbikes.com . if he says go, ill reccomend what he reccomended to me.
woodman components disco system disc brake adapter http://www.woodmancomponents.com/pro...scosystem.html aprox $110 and disco rear hub aprox $65. ive run mine for well over a year without issue in a variety of conditions and performance requierments with a avid bb7 brakeset.
according to turner, its the only system of its kind that doesnt break off the brake boss from the shockstay. if you decide to use this method, i may be prepared to part with mine now that i have a flux and a rfx frankenframe with disc tabs. the burner is being rebuilt to original spec and hung on a wall. well, after i take it for one final ride.
get an adaptor from Turner. Does it have another hole below the threaded one thats not threaded? If so you're in luck. The adaptor has one threaded hole and one unthreaded hole. This is how my 99 o2 was.
