Results 1 to 27 of 27
    Do It Yourself
    Reputation: Homebrew's Avatar
    Spot cable routing...
    Sorry the search function isn't working for me today.
    Fatal error: Allowed memory size of 8388608 bytes exhausted (tried to allocate 1024 bytes) in /data/data01/web/html/files/search.php on line 878
    Anyway, I routed the shift cables on my Spot in a criss cross up front (rear shifter around the headtube and into the left cable stop...) and crossing back over under the taco. The front cable seems fine but rear cable is getting crunched by the taco. Any suggestions?
    I really wish there was a center stop for the brake hose too. It just looks sloppy.
    Long Live Long Rides
    Amphibious Technologies
    Reputation: SCUBAPRO's Avatar
    Quote Originally Posted by Homebrew
    Pics would help. Have you looked at the routing suggestion/pics on the Turner website?
    "The best you've ridden is the best you know" - Paul Thede, Race Tech
    Do It Yourself
    Quote Originally Posted by SCUBAPRO
    I hadn't noticed that on Turner's site before but that's exactly how I did it. Maybe the cable is just be a bit too long or something. I know a pic would be helpful so try to post one up this weekend. Thanks.
    Bite Me.
    Reputation: cutthroat's Avatar
    Use the minimum amount of cable on the rear deraileur to get from cable stop to cable stop. It should be a fairly straight run with a minimum bow. That way when the suspension compresses you don't have a lot of excess cable flopping about. As for your top tube cable issues, I like these Jagwire cable guides. They stick right on and look good.
    When I see an adult on a bicycle, I do not despair for the future of the human race. ~H.G. Wells
    Roy
    Roy is offline
    Reputation: Roy's Avatar
    I have that same routing on my Spot and Pack. I wouldn't say the cable is getting "crunched", but I do hear it ticking as the suspension gets cycled and the cable contacts the taco.
    Just Grin and HUCK it...
    Reputation: SilverSpot's Avatar
    Quote Originally Posted by Roy
    ...but I do hear it ticking as the suspension gets cycled and the cable contacts the taco.
    I can't stand ticking, clicking and squeaking when I'm riding so I put a piece of velcro (the softer loop side) on the front of the taco to stop the noise and to preserve the cables. It ain't real perty, but it works.
    MCM# 2007.1
    3 "fiddy" for short
    Reputation: be350ka's Avatar
    Dec 2004
    I just noticed that my rear d cable is getting a cut in it from hitting the taco. So I did what any owner of a black 5 Spot would do...... I put black electrical tape on the cable.
    And here I thought duct tape was the ultimate fix!?!
    Do It Yourself
    With pics...
    Upon futher investigation, I didn't quite have the front derailleur like Turner's recommendation. So I've moved it but that still doesn't seem to fix the problem.
    Thanks for the tip cutthroat. I actually had one of those in the toolbox and it worked like a champ to clean up the brake housing.
    But back to the main issue here. I might be able to trim a bit more off the housing but after looking at the housing at full travel (second two pics) I don't think that will be enough. Any other ideas or is this just the way it is?
    Maybe a short piece of small diameter tubing slit down the middle, and placed along the taco edge? Not sure how to make it stay in place.
    I'm building an RFX as we speak, and I'm going to try 1/4" black irrigation tubing. I'll let you know if it stays in place for the first ride.
    Whining is not a strategy.
    Turner Homer
    Reputation: dtrek4500's Avatar
    I would also consider routing the cable on the outside of the taco, becasue that is how I have mine on my burner.
    Dave
    \|/Home of the Braves\|/
    Reputation: RedRocker's Avatar
    So far so good this way. Of course I've only had it a week. But what a week it's been
    Big hoopy.
    Turner Sultan / On One Inbred
    Congrats on reaching 1,000 posts cutthroat (shameless attempt to pad my own).
    Big hoopy.
    PSI
    PSI is offline
    I want that one
    Reputation: PSI's Avatar
    Mar 2005
    me like zip ties
    I think i picked this up from someone else on this forum, plus i guess i have a pretty bad zip-tie fetish. it works though.
    p.s. the psylo is temporary
    p.s.s what language on the heineken?
    Roy
    Roy is offline
    I just deflated my RP3 and checked the housing at full compression - looks just like yours. My housing is holding up better but it must just be a harder plastic casing. I would just put electrical tape around your wear spot.
    Looks like Hebrew to me.
    Big hoopy.
    Do It Yourself
    Quote Originally Posted by PSI
    That's what I did for today's ride. As you can see in the second set of pics, I switched the front derailleur over to the drive side. Today, I zipped the rear derailleur housing to the front derailleur housing. Seems to working okay but it really puts a bad bend in the housing and it may be my imagination but I think I'm getting some ghost shifting at deeper travel. It's not that big of a deal but it is an annoyance.
    ...but I think I'm getting some ghost shifting at deeper travel...
    Heck, coming off a 4" Burner I'm really impressed at what the Spot can do pedaling in its travel. There's a place on the trail I rode today where there's a sequence of :
    A left turn down a quick downhill
    About 15-20 feet of "trail armor" - what amounts to about a long flat-ish rock garden
    A 1 foot rise with a big root right at the crest
    The key is to keep enough momentum to clear the root. On the Burner I focused on the garden and tried to build a little speed right at the end. It can be a chain snapper! On the Spot I can pedal across the whole thing and glide right over the root with plenty of speed. I'm in luuuuuuuuuuuuuuuv!
    Big hoopy.
    ... I guess you won't be
    Reputation: jokermtb's Avatar
    Schmaltz = Chicken fat
    THAT is some funny shat!
    Big hoopy.
    trail fairy
    I got my the boys to set my cables up though I don't like how they crissed crossed them at the front its not nessecary at the front!
    But the back end is sweet very nice
    I also used some clear plastic protection sheets I bought at a motorcycle shop Moto x stuff really good..
    MAXXIS 4C!
    Helmet for your neck
    Leatt FAQs
    PSI
    PSI is offline
    I want that one
    Mar 2005
    Quote Originally Posted by jokermtb
    thats cool. i guess if you have hasidic reggae in brooklyn (http://www.ttgapers.com/module-ttSto...0007XT7TU.html) you might as well have hasidic beer.
    in israel the only microbrewery is here: http://www.taybehbeer.com/ not jewish but close enough.
    The short pieces of plastic tubing, slit down the middle, then "clipped" onto the taco worked well, and stayed through 4 hours of riding with no adhesive.
    The black irrigation tubing didn't really work, so I tried clear tygon tubing. Perfect. It's got a little natural stickiness that seems to hold it in place.
    For paint protection I decided to drop the BIG DIME on a roll of helicopter tape. Expensive, but one roll should last long enough to protect the wear spots on my walker when I'm 80!
    Flyin Canine
    Reputation: shanedawg's Avatar
    Hey Homebrew, are you running a shimano rear derailluer? I switched to sram and haven't had ghost shifting since then.
    Lay off the Levers
    Reputation: Bikezilla's Avatar
    Hey Homebrew I just noticed something... it looks like at full compression your cable ferrule is outside of the cable stop. Unless it's a really long ferrule it's shifting out of the house and that would mean it's pulling more cable thus causing ghost shifting. I have my cable in the same location, and about the same length (too short) and I don't get ghost shifting. I also used a plastic edge cover on the bottom of the taco and clear 3M protector tape on the seat tube to help keep the cable rub in check.
    Faster is better, even when it's not.
    Do It Yourself
    Quote Originally Posted by shanedawg
    Yes but I'm still using 8 speed.
    Quote Originally Posted by Bikezilla
    It's not out of the cable stop. These are the Jagwire/Avid machined ferrules for 5+mm housing. The ferrule has a wider portion that the housing goes into (as seen in the pic) and another smaller portion that goes into the stop.
    Flyin Canine
    I hear ya, 8sp is less prone to shifting issues, but sram x-9 is still a noticeable improvement even over 8sp shimano in this area.
    Flyin Canine
    fwiw here a shot of my setup under full compression. It's a bit diff than yours since it's a small 2001 RFX. Even with this gradual bend in the cable I still had ghost shifting when I would drop to flat doing urban riding. I left the same middle cabel section in when I swapped derailluers. The shifter and der fixed it for good.
