Results 1 to 9 of 9
    stl_burner
    Reputation: stlburner's Avatar
    Dec 2004
    Shock Hardware..................Now.
    Where can I get shock hardware today? No local Turner dealer in St. Louis. I've tried True Value Hardware, Home Depot, Auto Zone.
    If you're looking for the bushings, you should just call the shock manufacturer for the specific ones. As far as bolts go, try giving Turner a call, any local shop should have one whether they carry Turners or not, or try the hardware distributor McMaster Carr
    stl_burner
    Dec 2004
    But....
    I need them today, so I can ride this weekend. Turner can get them to me, just not immediately. I don't need the bushings, just two bolts, four washers, and two nylon locknuts. 6mm x 40mm
    Outcast
    Reputation: Renegade's Avatar
    If you want the hardware NOW, get a phone book, start calling the other hardware stores in your area and ask them if the have M6, grade 8, socket head cap screws, and lock nuts to fit them.
    rr
    rr is offline
    I don't do PC
    Reputation: rr's Avatar
    Quote Originally Posted by stlburner
    Go to a local hardware store that has a good selection of bolts/nuts, Home depot and other type stores don't have as good of a selection, you will find something that works if not the exact thing you need. What happened to your exisitng hardware?
    stl_burner
    Dec 2004
    Existing Hardware
    The existing hardware is in the mail. Hopefully it will be here today, but I'm looking for a backup.
    Rolling
    Reputation: lidarman's Avatar
    Have you heard the saying?:
    "Failure to plan on your part does not
    constitute an emergency on my part."
    stl_burner
    Dec 2004
    Well thanks for the wisdom, but the hardware is not here because the shipper forgot to include it with the frame, which arrived last Friday. I apologize if I implied an emergency of any sort, I'm just excited to ride my new Spot and am looking for some advice on where to search for some temporary hardware.
    Quote Originally Posted by lidarman
    Outcast
    Rich, stlburner probably doesn't have a McGuckins in his town.
