    Reputation: Razorrazoo's Avatar
    Jul 2013
    Shimano 2x10 on 2009 5 Spot
    Does anyone have this set up and if so do you have any advice? Interested in things such as BB spacer location etc. Will be using SLX with a 38T outer ring. Won't be using a bash or chain device.
    Jul 2013
    Had a super quick response from DT via email;
    Start with the spacer on left if you want best chain line,, but if the derailer is being contacted by the dw-link at full travel AFTER the derailer limit screws are correctly adjusted then you may need to move the crank to Shimano spec.
    ran a XTR M970 with 24/38 Blackspire chainrings 10s 12-36 no bash guard XT med cage with clutch. Worked very well, its now sitting on a Sultan
    Jul 2013
    All seems to work fine with spacer on none drive side, plenty of room to fit the modded front mech at the right height. Getting slight rub from front mech at the limit of the stop from the 38T front to the 36T rear which I'll try an adjust out but may have to live with.
    Set up is SLX 2x10 F&R mech (front mech dual pull mod as per Turner website), SLX 38/26 double. SLX BB with BB spacer on none drive side.
  1. SRAM 2x10 crank with Shimano 2x10 system
    By Vhom in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-10-2013, 12:42 PM
  2. Shimano XT 2x10 with Shimano 3x9 derailleur and shifter
    By Bech in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-22-2012, 03:02 AM
  3. DW 5 spot 2x10 chain breaks a lot?
    By bobo_krkk_NIN in forum Turner
    Last Post: 12-28-2011, 10:28 AM
  4. Will SRAM X0 2x10 fit a 2010 DW Spot?
    By Digger90 in forum Turner
    Last Post: 12-12-2011, 06:49 PM
  5. x0 2x10 on HL spot questions
    By jh_on_the_cape in forum Turner
    Last Post: 04-04-2011, 06:45 PM
