Results 1 to 6 of 6
    Reputation: Rey Recinto's Avatar
    Mar 2005
    RS Monarch RT3 rear shock for 2012 5 Spot
    Hello bike gurus.
    I recently bought a 2012 Anno Orange Small 5-Spot Frame at ProBike Hong Kong (thanks to Mr. Patrick Cheung of PB). It came with a Fox Float RP23 Kashima Coat rear shock which I intend to replace with an RS Monarch RT3.
    What rebound and compression tune of the Monarch should I get? M/M or L/L? I am 150 lbs who loves bombing the local trails in the Philippines.
    Any suggestions guys?
    I plan to use an RS Revelation WC tapered 150mm Fork Single Air up front.
    L/l
    Feb 2007
    fox 34 160mm float
    Now with flavor!!
    Reputation: kidwoo's Avatar
    Light compression, medium rebound.
    I'm only 10lbs heavier than you and have to run the rebound damper completely maxed. If I had a few more clicks, I'd use them. It's still just a tad fast, even maxed out.
    STRAVA: Enabling dorks everywhere to get trails shut down........ all for the sake of a race on the internet.
    Definitely go for a Light compression. I'm on a M/M on my RC3 Plus and sadly it's a bit too harsh.
    Mine is a L/L, I tried a M/M and it was too harsh
