Results 1 to 18 of 18
    Natl. Champ DH Poser/Hack
    Reputation: cactuscorn's Avatar
    rroeder, el chiggy: yer prayers have been answered!
    say goodbye to yer r ders lookin like a wind chime! the system is kinda expensive but it comes with a lot of free stuff.
    No, I'm NOT back!
    Lay off the Levers
    Reputation: Bikezilla's Avatar
    That's hilarious... who the fock needs a sealed drivetrain for a cafe cruiser?
    But if it makes it to a proper MTB then we're talkin turkey!
    Too bad Ts isn't around... I bet he'd try to bolt one up to his RFX.
    Faster is better, even when it's not.
    TNC
    TNC is offline
    noMAD man
    Reputation: TNC's Avatar
    That's sweet! Pop in a set of 4:11 gears and some cheater slicks and head to the strip. I don't know, CC...all that might happen is that EC would trade broken rear ders for twisted drive shafts...LOL!
    Quote Originally Posted by Bikezilla
    wasnt that him in the pic?
    yeah, if it were to trickle down into a light, reliable system someday, that would be a substancial move fwd in drivetrains.
    No, I'm NOT back!
    Team Sanchez
    Reputation: El Chingon's Avatar
    That is pretty sweet. I e-mailed DT and asked him to include the drive shaft system on the XL Highlines!
    long standing member
    Reputation: PCinSC's Avatar
    What do you mean if? They've already got one. Check out that beefy rear shock.
    Lay off the Levers
    Yeaaaah baby, Return of the URT!
    I'm gettting out my credit card right now.
    Can you imagine that hot rod with an Avy bolted up on it?
    Rolling
    Reputation: lidarman's Avatar
    What?
    "....they would never go back to a chain motorcycle...and it's the same for bicycles once you ride a chain *studder* bicycle, you'll never go back."
    How true that is!
    He screwed up! LMAO.
    notabouttoseeyourlight
    Reputation: coma13's Avatar
    Does Craig make a 3.5"x1" version?
    cycle tracks will abound in utopia.
    hee hee, they said "shaft drive".
    (sorry, somewhat starved for juvenile entertainment today)
    Whining is not a strategy.
    rr
    rr is offline
    I don't do PC
    Reputation: rr's Avatar
    I honestly think a Saint setup would solve my der woes, problem is I'm addicted to gripshift and the Sram shifting, the rear der/hanger is not designed for the type of riding or terrain that a full travel rig like an RFX allows us to ride nowadays. DT also said he *might* do a Highline type der guard mount for the other models when/if he does the rear Maxle, I bet that would be more durable but the der would still need to be beefed up like the Saint.
    Knomer
    Reputation: Dusty Bottoms's Avatar
    Quote Originally Posted by rroeder
    With the emergence of the top normal Saint offering, I'm about to give Shimano another chance. Taking the hanger/dropout out of the equation is a huge step forward. Then add a MUCH beefier derailleur and you might have the strongest and most efficient drivetrain available. Rohloff & G-boxx both suffer from drag, and proprietary componentry woes.
    SRAM's attack shifter will enable you to grip shift a Shimano derailleur.
    rr
    rr is offline
    I don't do PC
    Quote Originally Posted by Dusty Bottoms
    I used to run the gripshift with Shimano der's before Sram came out with their der's, it wasn't near as light action or precise. I was seriously considering the Saint setup but the problem is I've decided to go with a lighter trail wheelset to compliment my existing heavy Sun Ringle wheelset, I will need to switch between them depending on the ride and it's too much hassle to switchout the shifting also. I even went as far as asking SR if I could retrofit a Saint axle on my existing rear wheel and they said no, so I would of had to rebuild the rear wheel with a saint hub, have the new wheelset built with a heavy Saint hub AND use Shimano shifting, not worth it for me.
    Reputation: Clyde S Dale's Avatar
    Jan 2005
    Quote Originally Posted by PCinSC
    I like where they've put the pivot. Unlike a BMW motorcyle it won't suffer from "torque rise."
    Captain Underpants
    Reputation: Random Drivel's Avatar
    Hey, it's good enough for BMW . . . .
    Rolling
    rroeder needs this around here...
    shaft drive on the front.
    rr
    rr is offline
    I don't do PC
    Looks like the perfect rock crawler for Palmer
    lx cranks? uno s/post? riser bar w/ bar ends? and a flite saddle? the spec is wacked!
    No, I'm NOT back!
