Results 1 to 40 of 40
    Reputation: antipop's Avatar
    Round and Round: Dreaded Wheelset decisions Post
    Hello,
    I read most of the threads I could find on am wheelsets and I still have some questions. I know that I want king hubs so I am researching rims and tires. My goal is to get a durable wheelset for that will handle lots of rocks and a 200lb + rider weight well. I would like a rim that can handle a 2.4 front. I have not decided whether or not I want to go tubeless or not. So far I like the mavic xm 819, the Dt Swiss Ex 500 and the ZTR flows.
    XM819:
    From what i have read the xm819 is super durable, UST ready, but is limited to a max tire width of 2.3. I have heard that it can handle a 2.4. Is anyone running a 2.35+ tire on a 819? Will it tend to want to roll over if I have a wider tire?
    DT EX500:
    So I read that the EX 500 is a new version of the 5.1. I have read a few comments about these rims being soft, but I have heard that they re-did the alloy after the intitial 5.1's and that the EX 500's are stronger. Anyone riding these? I like that they can handle up to 2.5". I probably won't go bigger than 2.4. Has anyone bought and used the Dt Swiss tubeless conversion for these rims?
    ZTR Flows:
    Seems to be the widest rim option. I have also heard that it is not eyeleted which = weaker at the spokehead. I will keep looking for info on the No Tubes conversion, but if you want to comment on your experience that would be great.
    I would also appreciate any good recommendations on 2.4" tires.
    disclaimer: all my info is based on e-research
    Thanks in advance,
    APOP
    life is steeper than it looks
    Reputation: tholarsch's Avatar
    Quote Originally Posted by antipop
    Hello,
    XM819:
    DT EX500:
    ZTR Flows:
    Thanks in advance,
    APOP
    Hi
    I have a set of CKs with 819s. The 19 mm inner diameter can handle up to a set of 2.4 tires with no problem, the tubeless feature works without any issues - In my experience its a fit and forget setup.
    I never tried DT rims ...
    I have another CK wheelset with the new Alpine rims. A great set of rims, the missing eyelets is not a problem, just make sure that the rims are built with even spoke tension. The Alpine is a light rim, but I use it for the same purposes as my 819s, and havent had any issues. I built the wheelset with rimtape and the olympic valve, and the tubeless feature works just fine. The rim has 20 mm innner diameter and works great with Mountain King 2.4.
    Good luck picking and chosing
    locked - time out
    That was the 6.1 with the soft alloy, like 4-5 years ago now.
    Seeeriously easy Livin
    Reputation: Flystagg's Avatar
    Nov 2006
    funny how that keeps comming up...
    locked - time out
    I searched google and found references like in the link below where people talk about how they read about the 5.1 having soft rims:
    So someone else will read that, and then write a post about it like this:
    Quote Originally Posted by glitz
    Thanks for catching me up on that
    Nice Glitz thanks for the laugh. I see your point. Too bad they won't read my disclaimer on the bottom of my post. Once I hear from someone that has used them I will edit my post and help stop the loop of madness for you.
    Hello,
    XM819:
    DT EX500:
    ZTR Flows:
    Thanks in advance,
    APOP
    What type of riding and what axle type do you need and why Kings?
    Quote Originally Posted by DHRracer
    Type of riding: climb what I ride down, I like technical chunk, jumps, obstacles, tricky climbs. I like riding fast on rough terrain. I like picking lines, I just want some durability when I miss. I generally do not worry about weight so much because I feel that I can always get in better shape and I can drop more lbs than my bike can.
    Axle: Currently 15mm QR but I may move to a 36 fork in the future. Rear is QR.
    Kings: I tried my friends wheelset and I liked how quickly I felt that I could get up on it. I could feel a difference between my hubs and the Kings.
    Thanks,
    apop
    Quote Originally Posted by tholarsch
    Hi
    Thanks for your input.
    bicycle rider
    Reputation: morganfletcher's Avatar
    Hello,
    XM819:
    DT EX500:
    ZTR Flows:
    Thanks in advance,
    APOP
    I don't think you have to worry about 2.4s on 819s. I'm running Fat Albert 2.4 UST snakeskins on 819s, LOVE THE COMBO! UST tires + UST rims + Stans sealant == perfect.
    I have Flows on my 29er, but if there was such a thing as a 29er 819 and 29er UST tires, I'd use them. Flows are great. Only downside I can see with the Flows is no eyelets, but so far with consistent, high tension (100kg) and a year of solid riding (205lb rider, torquey, single speed) I have no cracks, but I am starting to see some radial 'spider' marks at the spoke holes in the anodizing.
    Morgan
    Quote Originally Posted by morganfletcher
    Morgan
    Thanks Morgan.
    bicycle rider
    Thanks Morgan.
    Sure, I forgot to mention that I had a 5.1D (now the EX500) wheel and with the DT-Swiss 5.1D tubeless kit it was IMPOSSIBLE to mount a UST tire. I have several 4.2D wheels with the 4.2D tubeless kits, and have been able to mount and unmount UST tires, although they were tight. (Did break a steel core lever trying to unmount a flatted UST tire at last year's Downieville Classic race.) But the 5.1D + DT kit was IMPOSSIBLE! I'm big, no weakling. I scored the rim and broke / bent lots of levers trying to get a 2.4 UST Fat Albert, a 2.35 UST Nevegal and a couple other tires on it. My wife found me in the garage at 3AM, so freaking frustrated, bloody knuckles, the night before a Downieville trip. I later converted it with a Stan's strip with no problem. I got home, bought a pair of DT Swiss 340 hubs, Supercomp spokes and two Mavic 819 rims and built them up. That's what my 5.Spot is running now.
    Morgan
    Reputation: inkpad's Avatar
    4 years of hard riding & counting, Hadley 10mm through axle - 20mm front on 819's, could no be happier. Hubs are easy to rebuild as well. Rims are pretty sturdy too. Running Maxxis LUST 2.35 High Rollers, 6'-1" & 200lb rider. Tried others, always came back to these.
    Quote Originally Posted by inkpad
    Thanks for the feedback Inkpad. I will check the highrollers out. Do they like dry loose conditions? What PSI do you run on them?
    Best,
    Apop
    Best,
    Apop
    The tires pretty much work great in any conditions. I ride in anything from loose, rocky terrain to smooth, fast singletrack & have had great luck. I run about 32-36 in rear, 28-30 in the front.
    Cheers,
    Stu
    I've been running the Highroller 2.35 LUST on the rear - sick tire!
    I'm looking forward to trying the new Maxxis Minion DHF 2.5 single ply up front. Saw some in person a couple weeks ago and they look very impressive. Only about 900g too.
    MK_
    MK_ is offline
    carpe maņana
    Reputation: MK_'s Avatar
    Another light and wide rim would be Alex FR30. 30mm at 495g.
    5.1Ds certainly are not soft rims. They're very much a benchmark of 28mm rims that others get measured against.
    Lightweight 2.4 tires are hard. You very much get into a territory of personal preference and your riding arena. Each tire in that category is going to have a serious shortcoming somewhere. As example the Fat Albert is a fantastic tire as long as there isn't any moisture in my area. Once it get even a little damp the tire slides all over the rocks; and the rocks are sandstone. At the same time it seems very durable and offer fantastic grip/drive traction in most other conditions.
    _MK
    Before you diagnose yourself with depression or low self-esteem, first make sure that you are not just surrounded by a*holes
    Reputation: wilks's Avatar
    I am a big fan of 819s - wish they were wider but they are bombproof - I have been running ust high rollers 2.35 for years - I dabbled with conti mtn king 2.4s but they are cr@p in my opinion -most race tires have more grip in damp conditions..if I didn't run ust tires i would give 2.4 ardents a try.
    Quote Originally Posted by MK_
    _MK
    Thanks MK
    Quote Originally Posted by wilks
    Thanks Wilks.
    Quote Originally Posted by LncNuvue
    Thanks. You must be diggin' the larger tires. It seems you are going up in size again.
    bicycle rider
    I am a big fan of 819s - wish they were wider but...
    You know about the 823, right?
    Morgan
    Reputation: OldHouseMan's Avatar
    I've got Red Barn built 5.1s on King hubs and have been happy, just a solid rim on solid hubs.
    They don't seem to get much love on mtbr and WTB doesn't have them listed anymore, but I've been pretty happy with the 2.4 Moto Raptor here in the PNW. Seems like I remember reading they are in the 800gm range.
    I only ride bikes to fill the time when I'm not skiing.
    Reputation: qbert2000's Avatar
    Morgan
    heavy. i wish mavic offered that rim with interspoke milling like on the deemax wheelset. i'm pretty sure deemax are 823s milled down to save weight. you could always buy some deemax replacement wrims
    Morgan
    Yeah. A bit heavy and overkill for a Spot. They should make an 821 UST rim.
    trail fairy
    Kings or Hadleys
    Def go with 20mm and 10mm rear, Hadley's rear 10mm ti axle is unbeatable for weight and stiffness and usability!
    Rims yeah hard one, 819 for me to narrow for weight though good when compared to DT5.1s or Ex500s!
    Stans get a god rep if a UST
    Ive had my DT5.1s since early 2006 still true no dings though some good gauges and still running strong, I'm not light either.
    The Dts probably re converted me back to tubes on anything tire wise 2.3 plus because as said they are a straight out "bey ot ch" to mount UST tires too, Conti, Schwalbe and I had run UST from day one so I'm not new to it, I used to UST others, not now can't be bothered with it in bigger tires!
    I'd probably look at flows maybe and CKs or Hadley's what ever ya fancy, the DTs with tubes are rock solid though either wire bead or Kevlar no issue mounting them by hand, just UST beads
    Another rim maybe to look at is the new Sun EQUALIZERs in 29 or 27 I'm running 31s on my DH bike and am impressed by the quality and finish to date, not sure how they UST but anything with a rim strip these days can be done, they sure have the weights and strength sorted and easy to mount tires on some of the easiest Ive used to date, I can mount DH tires by hand.
    MAXXIS 4C!
    Helmet for your neck
    Leatt FAQs
    Moosehead
    Reputation: moosehead's Avatar
    +1 to the 819's laced to Hope/Hadley/CK's for Spot. Solid all rounder, UST's work brilliantly.
    For a lighter trail tire that climbs well I've liked the Specy Eskars 2.3's with Armadillo sidewalls. +1 to the High Rollers for a beefier setup.
    Quote Originally Posted by OldHouseMan
    _MK
    Thanks MK. Most of our local rides are rock, hardpack and loose over hardpack. I have only used Nevs and the Blue Grooves. The Nev's have worked well. But experimenting and tinkering is fun right?
    Apop
    Thanks fro the feedback Moosehead!
    Update
    Thanks for everyone's input.
    Here is what I picked.
    front hub
    Hope Pro 2 15QR (easy to convert to 20mm if needed in the future)
    rear hub
    King HD disc 135 qr black fun bolts
    frontt rim
    Mavic 819
    rear rim
    Mavic 819
    spokes
    DT Champion bk (straight 14g)
    nipples
    silver brass
    Thanks again!
    apop
    front hub
    rear hub
    frontt rim
    Mavic 819
    rear rim
    Mavic 819
    spokes
    nipples
    silver brass
    Thanks again!
    apop
    that's very sensible to use a hope front hub. i've got a couple sets of rims, two hadley rears and a king rear all with hope front hubs. very easy to convert and one of the best values in a front hub as well. their rears are a little too slow on the engagement but the fronts are great. you really can't go wrong with 819s, they are a little narrow and a pain in the ass to build but their quality is top notch. just finished the front wheel of my wife's new set last night, 819 and a king hd15mmqr.
    Quote Originally Posted by qbert2000
    Thats good to hear!
    Reputation: Whyaduck's Avatar
    Sounds like a nice set of wheels. I've got a pair of Hopes laced to 819s that I love. I run Spesh Chunder Control (2.35") up front and Eskar S-Works in the rear, tubeless with Stan's. Great combo on rugged, rocky AZ riding.
    You should have no problems mounting UST tires on the 819s. Been riding tubeless for 7 years and could never go back. 819s on 5spot and 823s on Highline. Been riding 2.4 front tire on the 819s with no problems. My favorite front XC tire is no longer available- the Specialized 2.4 Enduro 2Bliss- it was wider than my 2.5 Maxxis Highrollers, but light. I read Spec will be offering a 2.4 tubeless called the 'Purgatory'.
    ... I guess you won't be
    Reputation: jokermtb's Avatar
    I'm still running the ancient ancestor of your rim, the Mavic x3.1 tubeless rim, on a King hubset. It's pretty much the same rim with different stickers and eyelet furnishings, and it's very strong [I keep wondering how it long it's forcefield will hold]. The fattest tire I've had on it was a 2.5 WTB Timberwolf, and it was fun in a straight line, but came off the rim a few times when things got strange - however, I've never had any trouble with any 2.35 fat-carcass tire.....
    Don't sweat it!
    Quote Originally Posted by Whyaduck
    Thanks. I have never checked out speshy tires. There are so many tire options and opinions. It looks like i will take some local advice spend some cash and start building up experience.
    Quote Originally Posted by Spinster
    Thanks Spinster! This will be the first time I run tubeless. It will be a big change I am sure.
    Sweet! I think my stickers will make the wheelset way better. Heres to BNG! Good to hear they have held up.
