Results 1 to 15 of 15
    Romic Spring weights for 5-Spot
    Hi all,
    Just purchased a 5-spot and looking forward to building it up.
    This is a 2005 HL model with Romic shock (althoguht I understand that this rockers have the cut out for the RPŁ - does this make them 5.3 rockers?).
    Anyhoo.. the Shcok is coming with a 500lb spring. I can't seem to find a spring guide anywhere - how would this be for my weight (just under 14 St.) else what should I be looking at.
    On a seperate topic - any recommendations for front mech?
    TIA,
    Carl
    Stone?
    can you post a picture of the scale that has stones on it? I have always wondered what one looks like.
    The 500lb spring is for riders around 160-180 that much I do know.
    Have fun with your new ride.
    DT
    Reputation: Prof's Avatar
    indyworm a 550lbs spring will suit you.
    Stay off the brakes
    You're bang on my nekkid weight, and I use the 550 spring. I've got an RP3, but still prefer the Romic when riding the Utah rock.
    Whining is not a strategy.
    Imperial stones
    Try Mojo and TFT both have spring calculators on their web sites.
    http://www.mojo.co.uk/index1.htm
    http://www.tftunedshox.com/springcalc.htm
    ----- Couldn't find no stones DT, bricks OK. ---------
    Reputation: krispy@go-ride.com's Avatar
    I pulled this chart out of the file cabinet that DT probably forgot he made!
    5 Spot Spring Rates (Romic era)
    Rider weight Spring rate
    120-140 400
    140-160 450
    160-180 500
    180-200 550
    200-220 600
    220-240 650
    Santa Cruz Bronson 2 27.5/Rockshox Pike/Sram XX1
    Salsa Mukluk/Rockshox Bluto/Sram X1
    Thanks, just what I was looking for!
    Only problem now is sourcing a 550Lb spring in the UK. I might just get a 600lb spring and eat more pies.
    dressed to play
    Reputation: guitarhero's Avatar
    get the 550
    dressed to play
    get the 550
    dressed to play
    ooops
    dressed to play
    we are the same weight and i tried a 600 spring and it was definately too heavy.
    550x2 was perfect, and in stock here
    you can use 2 or 2.25 stroke springs
    Reputation: Kasper's Avatar
    Try Chainreactioncycles..
    http://www.chainreactioncycles.com/M...x?ModelID=3154
    It seems that 2,25'' romic springs doesn't come in 550 lbs (?)
    Speaking from own experience you could wait till after Xmas and the 600 lbs spring will probably fit
    Cheers Kasper
    Was that when you had a Turner
    Fancy selling it you must have been mad
    Shame on you
    Stay off the brakes
    dressed to play
    so true
    Quote Originally Posted by Prof
    Shame on you
    yup, regret that one big time
    DGC
    DGC is offline
    Reputation: DGC's Avatar
    #550x2.0
    Quote Originally Posted by Kasper
    Cheers Kasper
    The #550 does come in a 2.0 stroke. I dont think I have seen it in a 2.25" in the past.
    OUCH...!!!!!!
