Results 1 to 9 of 9
    Reputation: CrashTheDOG's Avatar
    Reba... The Wife of Frankenfork
    I'm outfitting my HT with a new RS Reba and I'd like to get a 20mm thru-axel on there. Does anybody know if Pike lowers will fit on a Reba? I believe they're both 32mm stanctions.
    Sep 2004
    Quote Originally Posted by CrashTheDOG
    Nope. The offset in the crowns are different.
    Why not get a Pike Dual Air and run at whatever travel you want?
    Quote Originally Posted by DoubleDown
    Bummer. I'll typically run 85mm of travel and bump it up to around 100mm when decending. Can the Pike run at 85mm?
    Bodhisattva
    Reputation: The Squeaky Wheel's Avatar
    Pike = 95-140mm of travel
    No, that's not phonetic
    Reputation: tscheezy's Avatar
    I think there is no minimum on how low the Dual air can be set, but you need a shock pump to change the travel in that model. The U-Turn air Squeak mentioned would be better.
    My video techniques can be found in this thread.
    Still on Training Wheels!
    Reputation: drum714's Avatar
    Before RS came out with their 06 line I saw a guy riding around on a Revalation with Thru axel lowers. Seemed to me to be a perfect Slolom fork, but I guess RS didn't see the need for a fork so close to the Pike.
    It's not a good ride if you don't scare yourself at least once.
    Yeah...I'm Sponsored..................by my Bank Account
    Living the Dream
    Reputation: Alpenglow's Avatar
    I think the air u-turn Pike 454 is actually
    Quote Originally Posted by The Squeaky Wheel
    110-140 mm. I have a Reba 115mm on my HT and it is awesome.
    "And I shout that your all fakes and you should have seen the look on your face"
    Bad Case of the Mondays
    Reputation: Jdub's Avatar
    Quote Originally Posted by Alpenglow
    Yep Air is 110-140, coil is 95-140.
    \|/Home of the Braves\|/
    Reputation: RedRocker's Avatar
    Revelation is 100-130. U-Turn seems to work over a range of 30mm. It is beefier than a Reba but still QR. Would that do it for you?
    Big hoopy.
    Turner Sultan / On One Inbred
