Results 1 to 5 of 5
    Reba failure Anyone want to comment on this?
    What transpired to make this Reba come apart? Please comment on all scenarios, like maybe the guy worked on his fork and...did what wrong? Could this happen to an untouched Reba (Rev, Pike)?
    Reba came apart during ride
    So it seems to me to be, this thing that I think I see.
    Quote Originally Posted by xcguy
    Um, all the necessary comments and analysis have BEEN made!
    That could not happen to an untouched shock.
    The guy failed to think that stanchion wear was a big issue.
    The guy failed to re-assemle properly.
    The guy failed to stop riding it when compression died.
    The guy added more air pressure as a crutch - which cost him his jaw.
    Quote Originally Posted by CharacterZero
    Interesting...
    Quote Originally Posted by Jerk_Chicken
    Interesting...
    I use homer jargon when trolling the homer bored! I am only prepping myself for indoctrination, you know..lol.
    Jul 2003
    I agree...
    a series of technical errors and errors in judgement most likely led to this.
    This has happened one other time that was posted on the forums that I am aware of. The final findings were the c clip was installed in the wrong direction and worked out of it's recess due to use. Most external c clips have a slightly beveled edge and a sharp edge. The beveled edge makes for easier instertion. The sharp edge needs to face away from the forces that would unseat it. So the sharp edge should face out towards the lowers in the case of reassembling the RS damper rod or air piston rods. Unless RS has changed their c clips recently this should hold true for current forks.
    Fortunately in the first instance of this reported on the forums, the rider said WTF!?!? when the damping went away, stopped riding, and went home to figure it out.
    Unfortunately in the current case the rider ignored the warnnings and paid for it.
    Good Dirt
