Results 1 to 3 of 3
    Ouch, I am hot!
    Reputation: Dirdir's Avatar
    Rear Der. Cable Noise
    My rear der. cable on 5-Spot is making temendous creaking noises at the housing/frame interface on the rear triangle. It is standard cable with the silver metal cable caps. I keep greasing, but this cure lasts a couple of rides. Any ideas what I can use cable wise or otherwise to stop? Anyone else have this noise?
    I AM JUST A JERK
    cask conditioned
    Reputation: endo verendo's Avatar
    Quote Originally Posted by Dirdir
    Replace you metal ends with plastic ones. Or put a small amount of tri flow or something on the end inside the stop.
    No, that's not phonetic
    Reputation: tscheezy's Avatar
    What endo said. These are the best since the little grub keeps all the dreck out of the housing. Sh!mano and Jagwire make them, and they are nice quiet plastic.
    My video techniques can be found in this thread.
  1. If you need to know this.
    By KevinVokeyJ24 in forum General Discussion
    Last Post: 12-24-2004, 09:40 AM
  2. Need a rear cable stop for V brakes I think. Help?
    By LocoMotoMan in forum Brake Time
    Last Post: 04-03-2004, 03:28 PM
  3. Replies: 1
    Last Post: 03-31-2004, 08:26 AM
  4. Replies: 7
    Last Post: 03-09-2004, 07:03 AM
  5. SID rear shock noise
    By dgangi in forum Shocks and Suspension
    Last Post: 01-26-2004, 09:01 PM
