Results 1 to 6 of 6
    Reputation: Whason's Avatar
    Which quick release skewer size for 2010 turner sultan?
    So what length quick release skewer for rear 2010 turner sultan? Trying to buy online and frame is at the shop getting prepped.
    Thanks in advance.
    "Chancho. When you are a man sometimes you wear stretchy pants... Its for fun..."
    135mm by 9mm. If you can go thru bolt on your rear hub do it. Then use a 10mm Hadley thru bolt
    OK thanks, so its standard.
    Yes
    I have never purchased a quick release skewer before. Always have come with wheels, and I have never had a failure. Does it matter at all which one I buy? Are some superior to others, or are they pretty much the same thing?
    meatier showers
    Dec 1999
    Quote Originally Posted by Whason View Post
    IMO Shimano makes the best. Not the fanciest, just the best.
    Discussion:
    QR Skewers, the good the bad and the ugly
    --sParty
    disciplesofdirt.org
    Remember who
    you wanted to be.
    Quote Originally Posted by riverrat
    Jaybo... quit *****ing and move to Texas
  1. nut spindle to quick release skewer conversion ???
    By sunstealth in forum Wheels and Tires
    Last Post: 03-18-2009, 11:08 PM
  2. quick-release skewer sizes?
    By mabittin in forum Beginner's Corner
    Last Post: 08-29-2007, 12:59 PM
  3. longer quick release skewer for use with chain tensioners?
    By ISuckAtRiding in forum Singlespeed
    Last Post: 10-02-2006, 09:50 PM
  4. Replies: 3
    Last Post: 04-09-2006, 05:20 AM
  5. quick release Skewer problem
    By iloveclimbinghills in forum Downhill - Freeride
    Last Post: 12-31-2005, 04:43 PM
