PUSH Linkage Bushings
Printable View
  • 12-28-2012
    DHRracer
    I ordered a set for TNT and a hat will I get an e-mail notice when they ship?
  • 12-28-2012
    wheatgerm
    Ordered a couple DW sets, plus some lovin' for my shock.
  • 12-29-2012
    nockmeister
    Has any stock been ordered by TFTuned yet?? Need DW sets here in the UK :)
  • 12-29-2012
    rmac
    Anyone figure out the shipping options for bushings only? The order form appears to only have shock and fork options.
  • 12-29-2012
    PUSHIND
    The shopping cart needs to be updated to reflect small part ordering. If you select Return Ground shipping you will get he cheapest option as they ship in a simple padded envelope. You can also add into he Notes field that you would like economy shipping, or for it to specifically to go via UPS.
    As for TF, I'm sure you'll have no problem getting kits from them. Shipments to them won't be far behind. I would recommend inquiring with them as to get on their list as we're going to work hard to accommodate everyone.
    Darren
  • 12-31-2012
    PUSHIND
    Update
    Initial TNT/HL kits are done! Just putting the finishing touch on the upper stay bushing fit and I'll let those rip! Shop is closed but I'm in here working for you guys on New Years Eve! :D
    I didn't order anywhere near enough material based on the demand so far, but I'll get more coming as soon as they can get it to us. Those of you that placed, or are placing, your orders early will see them start shipping in the next couple of days.
    Thanks!:thumbsup:
    Darren
  • 12-31-2012
    RaptorAddict
    Sweet! My order is already in so this is great to see!
  • 01-02-2013
    DaveR27
    i'll take a TNT set if you can post to the UK? the unbelievably bad weather has finally killed my 08 TNT RFX...
    please reply if you can do the UK??
  • 01-02-2013
    PUSHIND
    I spoke with TF Tuned this morning and we will be preparing to send kits over to them very shortly. Please forward your inquiries to them so that they can get you order sorted.
    Both kits began shipping today here in the USA.
    Darren
  • 01-02-2013
    Mr.Magura
    Originally Posted by PUSHIND View Post
    Sorry. For those of you unfamiliar with our previous kit, our PTX kit decreases dynamic friction by 50% increasing small bump sensitivity. It was very popular among TNT/HL owners, and we're just getting around to making them for DW bikes.
    Push Industries - Turner Frame Pivot Kit
    Darren
    Do you have a link to some info about the PTX material you use?
    Magura :)
  • 01-02-2013
    outlaw
    My DW kit shipped today and Invoice has 2 TNT/HL bushings as part of the kit? is this the case? here is what the invoice says..
    2 Pivot Bushing: Turner HL/TNT 2000-2008.
    4 Pivot Bushing: Turner DW Link: Upper Stay
    4 Pivot Bushing: Turner DW Link: Lower
    PivotPivot Bushing Kit: Turner DW-Link 2009-2013
  • 01-02-2013
    PUSHIND
    Yes the HL/TNT and DW bikes share the same main pivot bushings at the Rocker/Seat Tube pivot. I'm not sure why your invoice didn't reflect the updated description for the first two components. Regardless....you've got what you need on the way! :thumbsup:
    Darren
  • 01-02-2013
    outlaw
    Thanks, and by the way my monarch RC3 I got from you for my 2012 spot is killing it !!!!!!!!!!!!!!! endless travel back there. waiting for your 34 float kits?
  • 01-02-2013
    trojan08
    between outlaw's shout-out and Darren's pic I have massive shock envy. O' for the days of Push/Monarch tuning.
  • 01-03-2013
    RaptorAddict
    Darren,
    Could you share the dimensions for the flange OD and thickness on these bushings?
    I want to replace the standard rubber 'seals' with some proper quad-seal rings and I am just wondering what size to order.
    Any thoughts?
  • 01-03-2013
    PUSHIND
    The only info we have is what we supply the vendor in regards to what we're looking for. They then supply the material that meets the requirement.
    Darren,
    Any thoughts?
    0.860"(21.8mm) for Standard, and 0.925"(23.5mm) for lower DW link. Both approx. 0.05"(1.27mm) wide.
    To bad we don't have these quite finished.....Would make a great combo to the frame pivot kits!
  • 01-04-2013
    edispilf
    Darren,
    What's the torque specs required when installing PTX bushing? I remember 100 in/lb from previous installation manual. That's low compared to 27 ft/lb Turner use. I remember I mushroomed the shaft when I used 27 ft/lb. I'm speaking for TNT spot.
  • 01-04-2013
    PUSHIND
    Instructions
    Yeah, not sure how the instructions disappeared from the support tab of the site, but I reloaded them. Anyway, here's the link:
    http://www.pushindustries.com/2009/m...ll%20Guide.pdf
    As for the DW bikes, here's a link to the recommended spec's from Turner:
    Turner Bikes - Basic Maintenance
    Darren
  • 01-06-2013
    SlowMoe
    Hey Darren,
    I'll take one of each, as the wife is still on her TNT RFX.
    Moe
  • 01-30-2013
    neiloxford
    Measurement of DW Bushings
    Hi,
    Can somebody please provide the measurements of the DW Link bushings please? I am looking to source some from Igus as doing a cheap rebuild and looking for a cheaper alternative.
    The required measurements are:
    Shaft diameter d1
    Bearing width b1
    Flange thickness b2
    Outer diameter d2
    Flange diameter d3
    Schematic of bushing: http://www.igus.co.uk/r05/staticCont...nitt_Zeich.gif
    Link to Bushing Page on Igus: igus® Plain Bearing: iglidur® J
    Thanks Neil
  • 01-30-2013
    xcguy
    Good luck with that
    Originally Posted by neiloxford View Post
    Hi,
    Shaft diameter d1
    Bearing width b1
    Flange thickness b2
    Outer diameter d2
    Flange diameter d3
    Thanks Neil
    Measure your own stock bushings and go from there.
  • 02-18-2013
    vortexracing
    anybody fitted and ridden them yet, just ordered some from TFTune over her in the UK :thumbsup: but curious as to how people are finding them
    Ta
    Dave
  • 02-18-2013
    rhynohead
    Ta
    Da
    ve
    Installed DW bushings weeks ago. Had an issue installing the main pivot bushings and ended up re-installing the Turner bushings at the main pivot and now I have a little stiction, but installed the Push bushings on the rest of the bike. Only a couple of rides since so still breaking them in. Darren was cool to send me another set of main pivot bushings since I ruined them trying to install. It's a real tight fit, and I think I need to sand down the pivot shaft on the next attempt. I'll update after more ride time and once I get the main pivot bushings installed.
  • 02-19-2013
    PUSHIND
    rhyno, there should be no modifications necessary. You definitely don't want to sand down the hardcoat on the pivot pin. We've got hundreds of these installed without issue.
    Darren
  • 02-19-2013
    BarryGXNZ
    Thanks for that. It confirms how I thought it all went apart/together.
    Have to fit mine when I get back from NZ and have time to ride and break them in.
    Cheers
    Barry
    Darren
  • 02-19-2013
    wheatgerm
    Darren
    My main pivot bushings were definitely tighter than the other pivots with respect to fitting the pivot shaft. I small amount of bushing material was "shaved" off when pressing the shaft in.
  • 02-19-2013
    rhynohead
    Darren
    http://forums.mtbr.com/turner/how-do...rk-775924.html
    This is where I got the idea. Maybe I need to contact Greg to send me another pivot shaft that might be a bit narrower.
  • 02-19-2013
    TIGMAN
    Push + Turner = Pure Bliss ! :cool: TIG.
  • 08-05-2014
    TraxFactory
    Any chance you guys are going to turn a few more of these bushing kits? My Main and DW link are clapped out and in need of replacement ASAP.
  • 08-05-2014
    shupack
    I'd be in for a DW link set too.
  • 08-05-2014
    AlienRFX
    Would definitely be down for a set of DW bushings
  • 08-06-2014
    David R
    They sound like the business, I'd be keen for a set of DW ones too!
  • 08-06-2014
    TwoPumpChump
    I threw a set on my RFX a few years back. They were dunzo in about six months. Ended up putting the original Turner bushings back in and they have been running perfectly ever since. I don't doubt that they have less friction but the softness of the PTX did not lend itself to longevity.
  • 08-06-2014
    Velo_1
    Wow, 6 months? Mine lasted about 3. Went back to stock as well but they dont last as long as I would like.
  • 08-07-2014
    1soulrider
    The Push bushings in my Burner are going on 18+ months and working great. Nice upgrade imho.
  • 08-07-2014
    kidwoo
    Originally Posted by 1soulrider View Post
    Nice upgrade imho.
    .......If they were actually available :D
  • 08-07-2014
    Chasintrane
    Re: PUSH Linkage Bushings
    I've been able to get nearly 2 years out of the multiple sets I've owned as well. Make sure you guys follow PUSH's torque spec for reassembly. It's lower than the stock Turner delrin spec. It's a fantastic upgrade imo.
    Sent from my Galaxy Note 3 using Tapatalk.
  • 08-08-2014
    Velo_1
    How often are you guys riding your bikes to get that much use out of them? I ride a min of 8 hours a week on my spot...plus I weight 200lbs...im sure that effects the wear a bit. ;)
  • 08-08-2014
    TraxFactory
    I get about 6-8 months out of the Main and DW bushings before they get clapped out, this is with good maintenance too. Riding about 40 miles week MTB, weighing in at 225# ish.
    BTW, nice original avatar Velo_1.... :p
  • 11-26-2014
    ttchad
    Will these ever be available? Any other sources?
  • 11-26-2014
    renoirbud
    I called them a couple month ago and was told, they are planning on making some at some point, but no date is set.
    I guess its a demand thing, if everyone calls, we are more likely to get some?
  • 11-27-2014
    madamfunk
    Cool, how do you know when you're bushings need replacing?
  • 11-27-2014
    DHRracer
    What frame are you needing/wanting them for? DW or TNT I have a set for a TNT that I may not use. Frame 05' 6 Pack might be up for sale soon.
  • 05-04-2016
    Chasintrane
    Bumping to offer 2 sets of TNT/HL bushings for sale to my fellow homers. My plans to set the wife up with an older extra small Flux have not materialized. Bushings are brand new from PUSH. I hope this post is ok considering the classifieds are now free. I'd rather these bushings go to use!
  • 09-25-2016
    jokermtb
    still got these bushings? ^^^
