Results 1 to 13 of 13
    trail fairy
    Protoype FOX DHXc
    So here;s the new Prototype DHXc
    Apologies if already posted anywhere, just seen it on sicklines!
    MAXXIS 4C!
    Helmet for your neck
    Leatt FAQs
    Reputation: jncarpenter's Avatar
    I don't think that's a DHX
    trail fairy
    Quote Originally Posted by jncarpenter
    Kewel
    Just reading from Sicklines website
    Fox DHX Proto
    MAXXIS 4C!
    Leatt FAQs
    Amphibious Technologies
    Reputation: SCUBAPRO's Avatar
    Looks like it has external adjusters for HSC & LSC.
    "The best you've ridden is the best you know" - Paul Thede, Race Tech
    Lay off the Levers
    Reputation: Bikezilla's Avatar
    That sure is an odd way to spell Avalanche.
    Faster is better, even when it's not.
    Quote Originally Posted by Bikezilla
    Yeah, poppet and needle valves; right? Doesn't the CCDB use those too?
    "Its All Good"
    Reputation: Whafe's Avatar
    what is that saying, copying is the best form of flattery......
    Thank you Ohlins...
    Lay off the Levers
    Quote Originally Posted by SCUBAPRO
    Well according to Renny, having them and using them are two quite different things.
    Outcast
    Reputation: Renegade's Avatar
    yea, my panasonic receiver has poppets and needle valves, knobs and slidey things, but it still sounds like a panasonic, it ain't no Macintosh.
    I think they are good but to insist on not using the main piston valving is just silly; IMHO. Unless their marketing dept controls their engineering dept
    Quote Originally Posted by trailadvent
    Kewel
    Fox DHX Proto
    ...hence their "?"
    trail fairy
    ...hence their "?"
    True, I have found that the latest Journo info on the Boxxer was also misleading, its not 38mm its 35mm and its still using WC BB air technology
    Never believe all breaking news its just news not fact, hence why I out it out there or discussion!
    I know you guys have the ear closer to the ground and the right people
    Chur!
    MAXXIS 4C!
    Leatt FAQs
    Lay off the Levers
    Yeppers I know plenty of ppl very happy with the shock. Just like anything. As for the piston, yeah IIRC when I went with HIP to CC they were explaining about the super stiff shims on the piston that don't open much. But hey I'm sure they've designed it that way for a good reason, like to prevent disabling the poppets or something. If it works for most That's cool. I just like tweaking Renny.
