Results 1 to 29 of 29
    Lay off the Levers
    Reputation: Bikezilla's Avatar
    Pressing Matters to Attend
    Redbarn Delivery:
    I know, it's not a major acquisition, but hey it's winter here, I'm bored and I like taking pictures.
    I can finally get started on forking up my Highline:
    We'll see how these bearings hold up compared to my CK devolution which has much larger, external bearings:
    I need the DXC though because of the 14mm total stack height. My XL HL head tube is 6".
    Goodness help me, I took TA's advice and went for the CroMag stem instead of the Azonic.
    Monster block of metal, this thing. Now I'll have to replace my X4 stem for the 66 it'll surely feel wimpy by comparison.
    Prolly won't have time to start till Monday but I'll surely post something when I'm done.
    Faster is better, even when it's not.
    Natl. Champ DH Poser/Hack
    Reputation: cactuscorn's Avatar
    tiny bearings.... thats what i saw before orderin my dbl xc. i was lookin for a orbit 1.5 r but no one had em in stock. just scored a orbit z on ebay though it might nesesetate a new short crown.
    congrats on the new bits. boxes show up on my doorstep almost daily right now. im a busy boy.
    edit: watch those h/set seals. i busted 1 durrin the install when it slipped from its home in the upper cup and got smashed under the top cap, a spacer and upper crown. cc was very cool when i called to admit my moronic move and sent me 2 more on the house.
    No, I'm NOT back!
    trail fairy
    About time
    Only suggested it like 12 months ago
    Good to see someones keeping the US economy ticking over!
    Just surprised there's not 2 of everything LOL..
    MAXXIS 4C!
    Helmet for your neck
    Leatt FAQs
    Large member
    Reputation: Tidybeard's Avatar
    Feb 2005
    Now that stem is pimp. Not that I would expect any less, but that Chad fella is a rascal when it comes to this stuff. Nice work Lizard-King
    Knomer
    Reputation: Dusty Bottoms's Avatar
    No probs on those bearings for me yet. However, it's almost impossible not to damage that crown race during removal with a standard tool, should you ever need to do so. Be sure to hit those hideous blue plastic spacers with a black sharpie before install, or dip them in gold glitter.
    Director of Sales: Knolly Bikes
    I've seen a lot of those narrow clamp stems and have been a bit weary of them myself. I dig the low stack for short steerers, but they still scare me a bit.
    this works but its not cheap.
    No, I'm NOT back!
    Committed
    Reputation: 1soulrider's Avatar
    Those bearings in the DXC Flush will need replacement yearly in my experience. No big deal as they are fairly cheap and easy to replace.
    I usually fill the channels that the blue seals sit in with some waterproof grease (boat trailer axle bearing grease works well) before assembly. This helps keep the water and crud out a bit.
    Committed
    Quote Originally Posted by cactuscorn
    Damn, thatís pretty cool. A lot more expensive than a hammer and flat bladed screwdriver though.
    So incredibly worthless, and so incredibly awesome at the same time. We have one at my shop. It doesn't really work any better then a hammer and a screw driver if you know what you're doing for both, but its just such an absurd tool that its rad by definition.
    way more as a matter of fact but it doesnt wallow out or bend crown races or deform the crown tolerances like the screwdriver trick can and leaves nary a mark on anything when yer done so ya dont piss off the custys, all very unlike the risks and realities of the other option. it fits 1" all the way up to 1.5" too. my fave part of this tool is how efficiantly it works. the longest and hardest part of the job is pickin it off the tool wall. all in all it makes and saves me money.
    No, I'm NOT back!
    Reputation: airwreck's Avatar
    thats not a direct mount stem?
    Big Test Icycles
    Reputation: Hangtime's Avatar
    I run the XC Flush on my Highline. The adjustment knobs of my 07' 66RC2X just touch the frame on the down tube. I'm switching to a DC fork, Fox or 888 so for the time being I'm not that worried. Two seasons on the XC in Oregon and zero issues with watter or crud affecting the bearrings.
    Lay off the Levers
    I couldn't wait so I stayed up late and got started after midnight.
    Out with the old:
    the Park RT-1 HS remover tool worked fine once I flared the tangs a bit:
    Even with the deep set cups there was sufficient room to get full purchase:
    A few solid firm taps and the cups came right out:
    I was concerned having read so many horror stories about stuck 1.5 and deep set cups. No problems though.
    Trick: tie a loop of string through the head tube and HS before inserting the tool and you won't have to worry about catching the cup as it ejects.
    (but y'all knew that already)
    Removing and pressing headsets is probably one of my favorite tasks. Don't know why but I dig the precision fit.
    Pre-Set shot, It really was straight when I started:
    Then the upper cup:
    Wheeeee!
    It wasn't a bolt-n-go dealyo the first time. I had to adjust my lower crown even lower:
    No worries though. I still had plenty of room based on my earlier measurements.
    CC, SR1, Dusty, yeah I was quite mindful about the plastic seals. I def greased everything, and made sure I had grease in the grooves and on the seal. I expect the bearing might not last more than a year, it is indeed easy to change. The race took a fair bit of whacking with a PVC and hammer to get it seated, more than usual. If that's any indication, removing it will be a challenge. I of course have a spare for the other fork. I might try to gold tint the cnc'd logo on the stem. That would be cooli-o fer sure! Got some other ideas as well...
    As you can see a 14mm total stack height is pretty much the most I could get away with on a 6" head tube:
    Time for a touch-up on dem bars. I wonder if I can send them out to get anno'd? now where did I seee something like that before?
    When Zoke releases their high rise crown Maybe I'll put the CK lower cup on.
    JC, The Cromag Stem while low-profile, is bolt-on.
    In addition to the single clamp, it is bolted directly to the upper crown from below:
    Excuse the sloppy photo. Two bolts attach the stem to the crown.
    That puppy ain't goin nowhere.
    The 8" rotor brake boss lined up with my Formula T1 brake caliper perfectly. No more adaptors, no more shims.
    Sorry, no time for quality glamour shots today.
    Whoopieeee! this is one big arsed fork. Plush yeah, well from what I can tell sitting on a bike in the basement. Looking down at that monster rock beater I can see I'll have the old PF Flyer slogan running through my head all season.
    Wide arsed turning radius though. Good thing I have a 66RC3 waiting in the wings for the tight trails. That'll get fitted next.
    omg, that is maxed out!
    how about shaving some head tube off with a facing tool?
    cool to see the solid front end on there. Don't make assumptions about tight trails till you've tried it...
    Lay off the Levers
    I suppose I could take 2-3mm off the top and bottom of the headtube,
    *edit* I just checked. There's maybe 2-3mm above the weld on the top pretty much nothing available on the bottom.
    I think rather than a permanent change like that, I'd get the taller upper crown if/when it's available. Meanwhile this seems fine, as long as I don't run a 3.0 tire.(And that might actually fit too) The 2.6 Ardent has plenty of room and I'll check any other tire that looks larger when I put it on.
    Yeah I'll try the 888 on the trails too. Just nice to have the option to drop a pound and pick up some maneuverability for X-ups if I ever learn. Meanwhile I can learn tailwhips. (queue song "High Hopes")
    Moosehead
    Reputation: moosehead's Avatar
    that blinged stem looks like of one of these...
    Hisforever
    Reputation: SHAHEEB's Avatar
    Dec 2004
    Zilla, how come you took the king Off? did you need 1 1/8 for the fork? or just stack height adjustment by throwing the king out and going cane creek?
    Jesus Saves
    Reputation: Bollox's Avatar
    Yup, that CR 250 of yours sure is looking pretty!!
    Forward progress by Brute Force and Bloody Ignorance.
    Te mortuo heres tibi sim?
    Quote Originally Posted by SHAHEEB
    Double crown and single crown forks each with a crown race on to swap back and forth -> same headset left in the frame means he'll have super easy fork swaps when he wants.
    Or that's my assumption.
    Lay off the Levers
    Sha, Scrubby, Yeppers on both counts.
    The CK stack height is a great deal higher than the cc DXC. It flat out won't fit on the XL-HL with a 888, at least not until Zoke makes a taller crown available. Even then I probably will only be able to get the lower CK cup on with the CC top.
    And yes, I want to switch bwn forks as easily as switching tires. If I got the 66RCX3 in 1.5 I would have to change headsets with the fork swaps because the DXC can't be converted to 1.5 like the CK Devo can. The ID of the DCX cups are 1-1/8. The CK has external bearings so you only need to remove the insert of the upper bearing cap, get a 1.5 preload cap, and have a 1.5 crown race on the other fork. But again, the CK is too tall on a 6" head tube with standard 888 upper crowns.
    Moose, if I had one of those rings, I'd surely have my stem made to match!
    The hand models on CVT are improving.
    Where's the box for the Crank Bros. headset?
    Reputation: wmbarace's Avatar
    Sep 2004
    Lookin Good Zilla. Noce to see the carbon fiber spacer to keep the weight down.
    Chris
    Lay off the Levers
    Quote Originally Posted by wmbarace
    Chris
    It's there to balance out the 3rd chainring and eggbeater pedals.
    Reputation: krispy@go-ride.com's Avatar
    What kind of pedals are those??
    Santa Cruz Bronson 2 27.5/Rockshox Pike/Sram XX1
    Salsa Mukluk/Rockshox Bluto/Sram X1
    Outcast
    Reputation: Renegade's Avatar
    Kris, those pedals are made by Dark Cycles, the model is the Arachnid:
    Badass
    and comfy too! im gettin some for my beach cruiser.
    No, I'm NOT back!
    trail fairy
    Booty, AWESOME, zilla, loving the 2 888s on the HL
    Spanking
    MAXXIS 4C!
    Leatt FAQs
