Results 1 to 3 of 3
    Over the Hill
    Reputation: dstepper's Avatar
    Press fit headset and Bottom Bracket
    When building up a Czar are you putting the press fit BB (Parlee PF-30 to Shimano) and HS (Crane Creek 40) in dry or what are you using?
    Dean
    Worked fine, including drama-free removal of fragged Wheels BB for replacement with Praxis.
    Whining is not a strategy.
    Jun 2013
    Quote Originally Posted by dstepper View Post
    I used marine grade anti-seize (recommended by Praxis). I'm hoping it will be most long lasting.
    I will be interested to see if these press fit components end up completely stuck in the frame in 2 or 3 years. . . I had TWO carbon seat posts completely, permanently, and absolutely stuck in two different Turner frames in years past. Had to chisel them out. . .
    Also curious to see whether galvanic corrosion will be a factor with carbon frames and aluminum components.
  1. Why the press fit bottom bracket?
    By OldHouseMan in forum Ventana
    Last Post: 03-19-2015, 03:04 PM
  2. Press Fit Bottom Bracket?
    By guppie in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-07-2012, 09:03 PM
  3. XT crank on Press fit bottom bracket?
    By 247 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-28-2012, 01:50 AM
  4. best BB92 PRESS-IN BOTTOM BRACKET ?
    By razorjack in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-29-2012, 03:27 PM
  5. Press fit Bottom Bracket.
    By mudpup in forum Pivot Cycles
    Last Post: 04-01-2011, 10:37 AM
