Results 1 to 6 of 6
    Reputation: cooleymtnbiker1's Avatar
    Pivot shaft stiction
    Hey guys,
    Been working on a customer's 2014 Sultan for a few days now with a massive creak coming from the DW area. I've noticed that the pivot shafts are tight....like so snug they won't move as I had to force them out with a hammer and pick. How tight should they be? Same thing in the upper rockers as well.
    Reputation: freebiker's Avatar
    Mar 2006
    ? Did u call turner?
    They are that tight and seat in after a couple weeks.
    Reputation: shalesjr's Avatar
    There's been a lot written up about the creaking coming from the DW area on this forum. Basically, sand the anodizing off the outside of the shafts, regrease, insert, torque to spec. Has eliminated the dreaded creak on my Spot for a few months now.
    If they remain that tight after 20 hours of break in time, sand a bit off the i.d. of the bushings or the o.d. of the shafts and you're off to the races.
    The test is to put the bike in the stand, remove the rear wheel, and unbolt the top of the shock. If the rear suspension cycles easily and falls downward by gravity (or nearly so), you're good to go, IMO.
    The drive towards achievement and success is the motive power of civilization.
    Thanks everyone.
  1. dw pivot shaft life?
    By yoeddynz in forum Turner
    Last Post: 11-12-2013, 11:55 AM
  2. Damaged pivot-shaft
    By eiri in forum Turner
    Last Post: 08-28-2012, 10:53 AM
  3. Fox FIT dampers, what's with the stiction?
    By dodger in forum Shocks and Suspension
    Last Post: 11-16-2011, 09:44 PM
  4. Glory 2010 Pivot Shaft Diam.....
    By SABER_MTB in forum Downhill - Freeride
    Last Post: 10-24-2011, 03:37 AM
  5. Fork stiction
    By rswitz in forum Downhill - Freeride
    Last Post: 05-01-2011, 10:25 AM
