Results 1 to 11 of 11
    Reputation: CrashTheDOG's Avatar
    New question here. Painted Romic Springs...
    I know a few of you have painted your Romic springs. How is the paint holding up? Any cracking?
    rr
    rr is offline
    I don't do PC
    Reputation: rr's Avatar
    Good job!
    Quote Originally Posted by CrashTheDOG
    Had mine painted over a year ago and it still looks new. $40 at www.spectrumpowderworks.com
    No, that's not phonetic
    Reputation: tscheezy's Avatar
    I put "bumper black" on mine, a flexible, flat black spray paint. I did about 4-6 coats. I personally think the spring rubs the shock body sometimes, so I do lose a little paint off the inside of the spring in one or two spots. Otherwise it is doing ok. Even a scratched up black spring looks better than the original red.
    My video techniques can be found in this thread.
    Reputation: AndyN's Avatar
    No problems here
    I used black brake caliper paint, two coats. That hideous red is gone for good.
    Reputation: Guitarzan415's Avatar
    Hmmm, I like the red
    Reputation: Spongebob's Avatar
    Hey AndyN.......
    Quote Originally Posted by AndyN
    AndyN,
    Want to do the same. Did you use a kit (like $40), or just do a good cleaning and using a spray can, like from JCWhitney/local store?
    I got a quote from Spectrum Powder Works and it'll be $50 w/o shipping costs.
    SB
    We told you 650b rocks! Riding converted RFX for years!
    Lay off the Levers
    Reputation: Bikezilla's Avatar
    Quote Originally Posted by Spongebob
    AndyN,
    SB
    Gee, that seems pretty steep for a color change, considering one could buy a spring new, for ~$45.
    IMO the red ain't that ugly...but then I have a "gay red" 5 Spot
    Faster is better, even when it's not.
    AndyN,
    SB
    I just used a spray can, about $7 I think. I did a light sanding on it first, washed it, then did coats following the paint can instructions. It's holding up well as well as the original red paint did.
    Quote Originally Posted by Bikezilla
    Yep, they wanted $15 to strip it and $35 to coat it black. I think I'll get one from Larry and see if I can paint it Ti color and mark it '123Bikes'. Seriously, I'm going to try what AndyN did.
    My 5er is red too, but I have to play now that I've found the best bike out there......
    SB
    Reputation: jedoaks's Avatar
    I'd go for it
    SB
    No feedback yet, build kit is coming from Ventanarama. I can live with this paint job and the consequences. Rich
    I used a can of Hi Heat 1200 degree black BBQ paint, after sanding it down with 600 grit sandpaper and cleaning it very well. It worked great. Home Depot supplier paint. Thanks for the suggestion.
  1. Coil Springs for Romic Shocks
    By bcjoker04 in forum Shocks and Suspension
    Last Post: 11-30-2004, 08:12 PM
  2. 123bikes.com has Ti springs for Romic
    By JTP in forum Turner
    Last Post: 03-17-2004, 12:02 PM
  3. Ti springs for Romic?
    By HTail in forum Shocks and Suspension
    Last Post: 02-06-2004, 11:57 AM
  4. Ti springs for Romic
    By TT. in forum Downhill - Freeride
    Last Post: 02-01-2004, 09:18 PM
  5. titanium spring for 5-spot
    By BSG in forum Turner
    Last Post: 01-19-2004, 01:03 PM
