Results 1 to 39 of 39
    Reputation: jewels's Avatar
    offset bushings vs. works headset
    question about dropping the bb on my bike(s)...2010 spot and 08 rfx. Can those who have done either the offset bushing or the works hs, comment on your experience. I don't necessarily need a slacked out trail bike, but would like to sit into the bike more and be a tad lower, like my HL spot. read some threads, but honestly it just gets more confusing. thanks!
    Dec 2005
    I did both on my red 09 DW spot with a 160 Lyrik fork. I loved the 1 degree works headset, it made no noises and worked great. The eccentric bushing I made myself in the machine shop. It too worked great but I suggest you really check your clearances like at the back of the seat tube and the swingarm to under seat tube rib contact. This is where mine contacted but it may have been the 09 to 2011 swingarm warranty mixed bag of parts that caused these interferences. Also, the ecc bushing makes the DW linkage need or want to need a bigger than stock volume shock can(i.e. HV can with almost full of spacers). But I didn't quite get to the happy setup before I got the 2013 front. And the Pushed rear shock is tuned for the stock DW anyway. Now RFX shoul handle the ecc bushing way better since the links are way longer and the suspension geometry shouldn't be quite as effected.
    thanks suspman. When you put on the works HS, did you feel a noticable change in bb? There is a 7.75 coil shock (vs 7.875) that we have for rfx without interference issues afaik. Geometry feels great with it, I just u turn the lyrik down a bit. I will order the bushings for the rfx and give it a go, I want to propedal climbs. On the DW, don't want to bugger the suspension tho.
    Dec 2005
    No I didn't notice the bb change as much as the head angle. I'm sure it came down some but not enough to be crazy, it prob didn't do much since the lower stack may have increase from the King lower I was using. The rfx sounds like a super high bb if your doing bushings in addition to the short shock. Just remember every bit you shorten the shock the rear wheel gets lifted that distance times the leverage ratio of the suspension w a 2" stroke and 6" travel its a 3:1 so if you had that the short shock lowered the bb by .375" already. I think you have more stroke and the ratio would be less and the bb drop would be slightly less though. Have you tried a shorter stack lower cup? I used the Crank bros lower and its a few mm shorter. With a tall and raked out fork the littlest bit matters and brings back under you and into spec. Good luck.
    def won't run the bushings on the coil, that feels good, just heavy and no pp. only using bushings on the stock rp3. Now they both should fell similar. I will consider the bottom cup for the dw.thanks for the info.
    Dec 2005
    No problem.
    Moosehead
    Reputation: moosehead's Avatar
    Would please like to hear other's input on various anglesets.
    I tried the highly recommended Saar angleset on my '10 Spot with 150 Fox Float and did not get along well at all. It made the steering wonky enough that I lost confidence on descents and got blown off the trail a few times. Same effect at speed or slow, weighting front or sitting back. never figured it out. It was hard to tell if it was "floppy" or somehow binding the steerer but in either case it was disappointing enough to go back to stock, happily. It could have been my hamfisted wrenching but the install was double checked.
    Any comments would be appreciated.
    Quote Originally Posted by moosehead View Post
    I ran a Works Component's 2 degree heaset w/o any issues. Sounds like your bike was too slack ??? A binding headset would be detected riding or not.
    Dec 2005
    Keen, What did you put the 2 degree headset on and what fork and travel and ec or zs cups? What do you thing your head angle is at and is it too slack if in the 66's?
    Quote Originally Posted by suspman View Post
    KHS Flagstaff 29er. 120mm Manitou Tower fork W/ ZS cups. I had a 67.5* HA. My current 29er has a 66* and I like it.
    Dec 2005
    So would you say 66 is too slack for climbing at all? I have a Turner 5 spot w a 160 fork and 140 rear, but I still need to climb and don't want it to feel to floppy or slow me down even more climbing.
    Kinda, but do it
    I've been rocking a 1.5 works hs on my 11' Spot for almost a year now with a Lyrik U-turn. It gives me an approx 66 ha. You could feel a little wander in the front if it's not weighted correctly, but that's why I got the U-turn. I usually climb with the fork at 160, but more recently I crank it down to 140 for climbing. Plus, slack is hip
    I don't have an issue but depending on your riding style, cockpit setup & climbing preferances??? Lets just say it won't be any easier up but might be better down - tradeofff?.
    Dec 2005
    Hmm, rhynohead, are you using the 1.5 works 44mm flush bottom cup at 160 and what did it put your bottom bracket at? Also does it feel like the front axle is way out there now?
    flush bottom cup to keep the front end low and maintain the 66 ha I was looking for. BB at 12.75 and that's with big ass schwable HD's. The bike did feel quicker with a 140 on it, but I like the way it's set up for the way I like to ride (like a hack)
    1 5 Degree EC44 - ZS44 - Angle Headset Semi-Integrated type
    Dec 2005
    Yeah that is the one I was looking too to get the max slack and lowest bb. But that seems really low on the bb is that correct? I have my 2013 with a ZS44 headset at 160 Lyrik it was at 67.5 deg and 13.75 I think. Then at 170mm now and 67deg it is like 13.875. I want low but I may smack everything with a 12.75 bb. I know the Burner proto had low 13's and they raised it for pedal strike reasons. What's the deal?
    update with proshox bushing
    Installed the proshox bushing on the 09 dw spot and the 08 rfx (one bushing each). With the proshox bushings, remember to install them on the top of the shock, they won't fit on the bottom. I think it's because of the combination of size small frame and max offset at 3mm. Anyhow, on the dw i think it's just what I wanted. The rfx, on the otherhand, may need another one, it still feels a bit higher than i like. I emailed and asked if he'd make a 2mm bushing for me. thanks for all the great info.
    Dec 2005
    offset bushings vs. works headset-imag1505.jpgHi guys, I actually just had great luck with my 2013 DW Spot. I was running my lyrik at 160 with an EC44 lower and ZS44 upper, it was pretty good but at 67deg and 14". I wanted lower and a tad slacker. So I went for it and got the Works Components ZS44 EC44 1.5deg (the max they do w one ZS cup). Anyway its at 65.8deg HA and 13.625" BB with the ZS cup on bottom @ 160mm still. It is so stable and fast now its amazing!!! I do feel the cockpit length change but it felt a touch long stock, but also being on an 09 DW front and with the Works Components 1 1/8" 1deg headset I was used to the similar sized cockpit and now I am happy. It actually seems slower because it so stable. I confirmed on STRAVA though, everywhere faster. That makes me happy, instead of trying to keep this thing upright so much I can focus on line choice and launch point. Haha. I did like the eccentric shock eye on my old 09 DW lower but it affected the ramp up too much, these short links are affected a lot by link/shock geo changes.
    I love bike!
    Reputation: dsittman's Avatar
    Quote Originally Posted by jewels View Post
    So I've got a 3mm offset bushing coming in the mail and was planning on mounting on the bottom of my RFX (think it's an 07 maybe 08). Are you saying there might be an issue with the fit/clearance of the shock in the bottom mount? Figured this would be the best since the lower doesn't pivot as much as the top mount but if it doesn't fit well then...
    I love bike!
    I think you're right Frank...I got bikes all jumbled up. Not to mention my brain is a little jumbled up too. Thanks for the info.
    Quote Originally Posted by dsittman View Post
    I am referrering to both bikes, yes the 3mm doesn't fit on the bottom due to the shock body hitting the frame. BUT, as i said, I think it's because the frame size is small. I initially had in mounted on the bottom, thinking the same as you, then just flipped the shock body over. And model years may vary, i have an 08 small. I rode the dw yesterday and 1 offset was just right for me.
    I love bike!
    Ah...gotcha jewels. I have a large but I'll be sure to check the clearances through the full shock stroke. I've got a RS Monarch Plus on the way too so I have a couple new variables involved with clearance issues.
    Reputation: airwreck's Avatar
    What actually hits with the offset insert on the bottom is the eyelet part of the shock. Basically the lower shock mount does not leave any extra room for the shock to sit lower in the mount. Again this may only be a small frame issue.
    Frank, Have you switched to the new style Fox igus bushings from the old style brass with two piece alu inserts? The proshox insert is steel one piece.
    sounds correct, the big thing is the one piece steel insert axle versus the two piece alu. CC and RS have been one piece all along. Haven't checked it yet but the eyelet bearings may work with the Proshox offsets.
    Reputation: jet fixer's Avatar
    Feb 2006
    dsitman, where did you source your shock? I can't find one in stock anywhere I have to mail order as I live oversea's.
    Too fat for XC, and not skilled enough for FR
    ^ Same here. I can't seem to find a L/L Monarch Plus anywhere!
    I love bike!
    Had a hard time finding one myself. Finally found an ebay seller koo-us based out of the UK for $380 shipped to the US. Mine was a M/M though. Actually getting really antsy though as I've not got it yet and it was supposed to have shipped 9/23. Wishing I would have paid the extra $20 or so for tracking now as I don't have a clue where this thing is sitting.
    Reputation: Serotta b1kr's Avatar
    So, for an 08 RFX, which works headset is the right fit? Is it the EC44-EC44? I'm looking to slacken out my 08 RFX with a Talas 160. Would 2.0 be too much? thanks for the help!
    fill what's empty, empty what's full, and scratch where it itches.
    Dec 2005
    Don't believe they had the 44 headset then. Only standard 1 1/8th. I got a one deg one for my 09 spot from them at It worked great.
    Are you getting it for your RFX or a DW Spot? I used to have an M/M Tune on my DW Spot and felt that it was too harsh, that's why I sold it and I'm on the hunt for a L/L Monarch Plus.
    Hope yours arrived soon! The waiting part sure sucks.
    I love bike!
    RFX. Sux is an understatement...I'm jonesin to ride this thing soon as I've been off of the bike for @ 3 weeks now. Had to sell a single speed to fund the upgrades I'm putting into this bike so I've had nothing to ride.
    Feb 2006
    Quote Originally Posted by Serotta b1kr View Post
    For a 08 RFX the headset you need is:
    EC34 set 3
    Works Components - 1 0 Degree EC34 - Traditional 1 1 8 Fitment
    I had one installed for three rides then put the CK back in the steering felt sloppy to me.
    I also installed off set bushings top and bottom on a Fox DHX I've kept them in. My main goal was to lower the bottom bracket the slacker head angle is just a bonus.
    Burgtec Titanium Offset Shock Hardware | Burgtec
    7011 is the set for Turners.
    The next step is to see how it rides with a Lyrik instead of the vanilla.
    After that will be a monarch plus if I can ever find one in the size I need.
    thanks jet fixer and suspman! One more noob question, will the off set bushings work with any shock? I have the stock rp23 currently, but am considering upgrading to a coil or ccdb air cs.
    Yes, that's fonetic
    Reputation: whoda*huck's Avatar
    Feb 2005
    Serotta b1kr, Saar also makes anglesets for 1 1/8" head tubes.
    Feb 2006
    I know the bushings in the link I supplied will fit Fox and Rock Shox
    Reputation: juan_speeder's Avatar
    Y'know, when they ban Bryan A. aka mtb123, it'd be cool if they didn't delete all of his posts, as they usually contain good info, when he isn't railing against DW, at least.
    Scarlett Johansson loves my hummus.
    How's the HR2 on the rear? I have the 3C up front and was thinking of getting a 60A for the rear. Just unsure if it wears quickly.
    Oct 2007
    I've had a works headset for a couple of years now on my RFX and it's been flawless. Recently got some Burgtec offsets, I can only run one on my large frame (and that's with a small 1mm shim under the bottom out bumper on a dhx5) otherwise the swingarm only just makes contact with the seat tube, as I found out off a stepdown!
    A mate has a medium and can only run one offset with an RP23
    Also having trouble sourcing a monarch plus, interestingly enough it looks like a vivid air may fit in there
    The blue and white looks sharp on those bikes!
  1. Offset Bushings, Yay or Nay??
    By curbhuck in forum Ibis
    Last Post: 04-20-2014, 12:05 AM
  2. Offset Bushings.
    By rpm100 in forum Nicolai
    Last Post: 04-19-2013, 07:38 AM
  3. offset bushings
    By fua in forum Turner
    Last Post: 03-17-2013, 04:01 PM
  4. DW and Offset bushings
    By stumblemumble in forum Turner
    Last Post: 10-18-2012, 04:23 AM
  5. M9 with offset bushings
    By dans160 in forum Intense
    Last Post: 03-21-2012, 01:07 PM
Members who have read this thread: 7
