Results 1 to 2 of 2
    Ouch, I am hot!
    Reputation: Dirdir's Avatar
    Need Serious Help Installing New Romic Spring
    I just got my new Romic Spring and need help installing. I don't have "two left hands", but I do have a bigger problem. I just can't seem to do the easiest repair jobs right, and when I screw them up, I go ballistic. Can anyone help me and hold my hand through this? As Denzel said in Philadelphia, "explain it to me as if I was a 5 year old"
    Quote Originally Posted by Dirdir
    LOL... first back off the pre-load collar as far as you can. Meaning the collar that's threaded that moves up and down the shock body... wind it up the shock body until there isn't any tension on the spring... then keep unwinding. Enough to allow the spring to move vertically about 1/2".
    Once you're there. Pull the lower spring perch up until it can clear the seat on which it rests. You should then be able to pull the lower spring perch away from the shock body by passing the shaft through the channel in the perch.
    At that point the spring should just slip off of the end that the lower perch was on.
    Install the new spring in the opposite order of removal.
    Edit: the shock should be detached from the frame. At least the shock shaft end.
  1. Romic Spring For New 5 Spot
    By john mikesell in forum Turner
    Last Post: 03-20-2004, 10:08 AM
  2. Anybody got a romic 550x2.25 spring for sale?
    By FM in forum Shocks and Suspension
    Last Post: 02-20-2004, 08:11 PM
  3. When a spring is not a spring
    By WarrGuru in forum Turner
    Last Post: 02-11-2004, 08:53 AM
  4. Romic Spring Swap
    By Chris2fur in forum Shocks and Suspension
    Last Post: 02-09-2004, 01:40 PM
  5. What Romic spring weight on the 5 Spot?
    By wfl3 in forum Turner
    Last Post: 01-29-2004, 11:45 AM
