Results 1 to 15 of 15
Thread: My new 5 spot
    Oct 2012
    My new 5 spot
    Hello
    Just received my 5 spot frame. Looks Good, pics will come when it's done.
    But I'm wondering if the headset/head tube should look like this? The head tube is sticking out behind the headset. Is this normal? Anyone else have this? I'm getting a little worried here
    Attached Thumbnails Attached Thumbnails My new 5 spot-2013-01-07-20.08.47.jpg
    Reputation: ifouiripilay's Avatar
    Weird...
    Either the headset or headtube. I'm not familiar with nukeproof headsets so can't judge. I've haven't seen this before either. (Limited experience, just 7 self installed hs) You can remove the headset and measure the the Thickness of the headtube all the way around with some calipers. And do the same with the hs, measuring the lip ( not sure the proper term). I'm sure you can find out which is not in spec. Good luck.
    Oct 2012
    I would if I had the tools. I had the headset installed at a bike shop. I might get the tools soon.
    I hate this, this sort of thing drives me nuts!
    bump and grind
    Apr 2005
    If there is no binding and the headset/steerer turns freely, I wouldnt worry about it.
    more pix of the full ride!!!!
    My new spot does the exact same thing. I measured the exterior of the tube front to back and side to side, and the dimensions are the same.
    If you look inside the head tube, you can see quite a bit of machine work went on on there along with post anodizing reaming of the headset seats, don't worry about it.
    Yes, that's fonetic
    Reputation: whodaphuck's Avatar
    Feb 2005
    Nice color! Full bike pictures please.
    Oct 2012
    Quote Originally Posted by AlienRFX View Post
    Are the dimensions the same when the headset is installed? Mine are not, it's about 0.4 mm difference when I cross measure. But residue after machining is a hot tip. I have to check into that, but my tools does not arrive for about a week.
    Pictures will come when the bike is finished, there is still some parts missing.
    Rides Uphill Slow
    Reputation: The Hookler's Avatar
    Quote Originally Posted by samu View Post
    Hello
    My 2011 had the same issue (using a King headset). Got a 2012 and did the same thing. My 2012 was less obvious than the 2011. Still bugs me quite a bit considering how pricey these frames are.
    I'm here for the downhill
    Reputation: Guitarzan415's Avatar
    Quote Originally Posted by The Hookler View Post
    I have a 2011...same issue too. I have the ano Black so it really shows. Funny how I can still have a 100% great time on this bike. Just Ride!
    Reputation: Hangtime's Avatar
    Not trying to fuel a fire but that would drive me crazy.
    Voice your support for Timberline Bike Park
    http://www.timberlinelodge.com/mountainbike/
    I don't understand what the issue is???...that's just manufacturing tolerance since the tube ID is finish-machined after heat treat and anodizing. Are you concerned there's a structural issue, or just bothered by the cosmetics?
    whatever...
    OSCMTB
    Reputation: Berkley's Avatar
    Quote Originally Posted by Guitarzan415 View Post
    Just Ride!
    Bingo!
    Yes those measurements were made with the headset in place as installed by turner.
    The dimensions of the OD of the head tube are meaningless...in fact if it was perfectly round, I'd worry there wasn't enough weld penetration. The fact that the HT OD is distorted tells you you have good weld penetration.
    If you want to measure something, take the headset out and measure the ID. I think you're fine tho. My Turner and my Titus look the same.
    whatever...
Hot Deals
Contests
Latest Mountain Bike Articles
