Results 1 to 8 of 8
    PSI
    PSI is offline
    I want that one
    Reputation: PSI's Avatar
    Mar 2005
    Mondial !!! (and goats)
    PSI
    PSI is offline
    I want that one
    Mar 2005
    also, a couple hours later at the same spot with the goats i had a little crash going down and busted the knob off my decender post - check it out
    Aug 2005
    A true multi-use trail. Did they like to share trail?
    Lay off the Levers
    Reputation: Bikezilla's Avatar
    Kewl! hey have you ever tried to hop over one of those?
    Faster is better, even when it's not.
    not so super...
    Reputation: SSINGA's Avatar
    Goats are better than snakes!
    Nothing to see here.
    Outcast
    Reputation: Renegade's Avatar
    Quote Originally Posted by Bikezilla
    Kewl! hey have you ever tried to hop ON one of those?
    I corrected your question 'Zilla.
    Lay off the Levers
    Well that improves SS's post too.
    Outcast
    Quote Originally Posted by SSINGA
    Goats are allmost as good to hop on as sheep!
    I corrected SS's post now as well.
