Results 1 to 34 of 34
Thread: Light Seatpost
    Light Seatpost
    Can anybody recomend a light seatpost i got the the urge to shave some pounds of the spot and as my thomson is nearing the end a new post seems favourite, there was a post on here somewere about an alloy one that weighed about 125 grams if my memory serves me well, i think that somebody was selling them on ebay.
    I got a Tune Starckes Stuck for my spot and an extralite for my wife. But I would look into the SDG I beam setup personally.
    The Thomson is near the end of its life? How so?
    I might sound like GS, but if you're riding a spot the way it was designed, a Thomson post is a lightweight post and pounds should be shed elsewhere.
    HAHAHA...a 125 gram post on a Spot. It's so retarded it's funny. Sorry, almost moved my bowels laughing so hard.
    wot the fook are you on about, ok then pal would it be a better idea to save weight on things like skimpy tyres or superlight xc rims perhaps, stuff that does take a hammering?
    i can see why they call you JERK
    "they" don't call me "jerk"
    I named myself "JERK_chicken".
    speaks volumes
    You're really not going to save much weight by switching from the Thomson unless you switch to carbon and then it still won't be much.
    imo... You should only use a carbon post if you're relatively light and it's used for XC type riding without raising and lowering it a lot. A friend of mine broke his carbon post a couple of weeks ago. He's lucky that he wasn't seriously injured.
    As someone else here asked... What did you mean by : "....and as my thomson is nearing the end ...."? Is the post broken?
    no isnt broken its just a few years old n all the anodising has worn off the bottom half so its a kind of two tone thomson post, i just fancy a new post and wonderd what was out there? something light but not carbon?
    Now that's even funnier. SO the seatposts works is what you're saying.
    Too funny.
    locked - time out
    Reputation: TIMBERRR's Avatar
    Feb 2006
    thompson vote.
    Lay off the Levers
    Reputation: Bikezilla's Avatar
    I guess it depends on the kind of riding you do. If it is fairly agressive, the post is not the place to save weight. If it's mostly XC and spinning through woods than anything light will do. If you fall over more than once every couple of rides then forget the carbon post, esp if you adjust your seat height frequently.
    I think Blue's made a good point, you won't be saving much weight anyway...but if you really want expert opinion on light parts, re-post this question in the weight weenies forum.
    Faster is better, even when it's not.
    Too funny.
    JERK CHICKEN, how did i get pesterd with a prick like you?
    I know what your saying bout the strengh of a post but on the aggresive stuff i drop the thing anyway thats appatr from the fact i'm only 10st pissed wet through. i've had the thomson bout 4 years n just wana change, is that so weird?
    ok:
    Tune Starckes Stuck
    Thmson Masterpiece
    Moots Ti post
    Hope that helps.
    cheers fella,
    bike weenie
    Reputation: RWGreen's Avatar
    Dec 2004
    money no object? what about this?
    http://www.schmolke-carbon-titan.de/...ndex_c_uk.html
    How about Thomson Masterpiece?
    Roy
    Roy is offline
    Reputation: Roy's Avatar
    What's your bike setup - maybe we can help identify better areas to lose weight:
    - seat itself
    - front shock/rear shock
    - wheelset - this is a biggie
    - cranks
    M070R-M0U7H FR3NCHI3
    Reputation: Acadian's Avatar
    Get your freak on!
    Do a search on the weight board for 'kcnc'. That is probably the light weight Alloy post you are thinking of.
    I reccomend the thomson masterpeice - bombproof and light.
    small 5spot
    rp3
    maverick ducs
    maverick front hub
    hope pro 2 rear
    mavic 819 ust rims
    xtr rear mech, front mech and shifters
    magura louise fr brakes
    race face dues chainset
    candy sl pedals
    race face next carbon bars
    thomson seatpost
    fizik gobi saddle
    maxis high roller 2.35 front tyre
    panaracer 2.1 rear
    both tubeless
    its wieghs in at 28.6lb's and it may sound daft but i think it should be lighter, besides the fact i need a new seatpost
    ya thats it kcnc, are they any good?
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    Thomson.
    MEM
    MEM is offline
    Use Thomson Masterpiece is the best choice. I have one on my 5 spot.
    It weights 193 grs, 27.2x 330 mm / Straight, it is 100grs lighter than the elite (27.2x410mm)
    Looks like the Elite --> Quality-Strong
    See this page, there are many components with the real weight to compare:
    http://weightweenies.starbike.com/listings.php
    When the Elite is cut down or ordered in a length at 330, how much of a weight difference is there between it and the Masterpiece?
    Don't be a sheep
    Sep 2004
    Quote Originally Posted by MOZWAFC
    Why. Just start over rather than hamstringing the Spot. Get a flux and weight weenie it up and be done with it.
    is the masterpiece the same grade of alloy and just machined out more?
    Get your freak on!
    Quote Originally Posted by Jerk_Chicken
    About 30 grams I believe.
    As for the KCNC seatpost - Can't say.. I have not used one, but i hear good things about their products. And as far as I'm aware - the seatpost doesn't have a weight limit.
    I personally love my thomson seatposts, but am currently looking at getting a USE seatpost. (light, good value and fairly strong!).
    Reputation: CDtofer's Avatar
    MOZ
    See here:
    Thompson
    According to their site and weight weenies the difference in the same size post is going to be 40 grams or so. Not huge but could be worth it if you lighten up a few other areas at the same time. What about seat? If you could get 80-100 gr from switching seat and saddle it could be worth it. I would second the poster that said to take a look at the SDG I-beam setup, I bet you could lose a fair bit of weight without comprimising too much on strength. (You can keep the old setup and swap for more agressive days) Even better what about tires??? Maybe better price/weight saving ratio to trade out to different rubber???
    Good luck Moz
    Hey homers, no doubt saying to go with Thompson masterpiece is good advice but whats up with the 'dude you cant ride your bike that way' comments??? WTF??? Especially since no one has asked him how light he is - yet. Maybe, just maybe he is light enough to run a carbon post without too much worry. I thought that shite was for the other boards and the beotchen about light bikes was Gonz's job. (and he even makes valid points on occasion) Anyways enough BS from my soapbox, Im going for a ride...
    Later
    Reputation: gonzostrike's Avatar
    Race Face Deus
    Salsa Shaft
    Thomson Elite
    yo mammy's broomstick
    Quote Originally Posted by CDtofer
    "on occasion"? hah! don't blame me if you misread my excellent posts. underbuilding a bike is a CRIME, I tell you. a bloody crime.
    I have lightweight seatposts on all my bikes. I get away with that because (1) I am smart enough to not ride sitting-down while dropping curbs or mid-trail tall obstacles; (2) I don't carry around 100lbs of extra fat that accumulate because I simply admire my bikes instead of actually riding them; (3) I don't choose piece-of-shyte seatposts.
    i think a seatpost is 1 place you can afford to save weight,
    especially if you choose one that's well made.
    The opposite is what reality is based on, especially when you're riding a 5 Spot.
    Maybe you should have bought a road bike instead?
    i have a road bike nobby, can i just remind you that a 5 spot is go anywere almost do anything bike so for me its got to be light, one step below get a flux one step above and get a 6 pack.
