Results 1 to 10 of 10
    Reputation: Mr Tiles's Avatar
    Just found out...
    ...that I could use the king +5mm lower race with my cc110 hs. It works PERFECT. I really didn't want to run the king lower cup to remedy the talas knob hitting the DT. Both headsets use 45^ contact bearings and the bearing races are apparently compatible. STOKED!
    Reputation: flipnidaho's Avatar
    Yep.. On my old Canfield (which had really bad clearance), I ran the Cane Creek +5mm Lower Cup with the Ventana made +7mm CK crown race and it was a perfect fit as well...
    Rides like wrecking ball
    Reputation: Bulldog's Avatar
    Quote Originally Posted by flipnidaho
    The S3 +5mm cup/bearing works with the Ventana +7mm race?! Ohhh this could finally solve my problems on my hardtail!
    Quote Originally Posted by Hesh to Steel
    With people liking mongoose and trek bikes now, what's next in this crazy world? People disliking the bottlerocket?!
    Quote Originally Posted by Bulldog
    Sure does but you probably won't hear it recommended by Ventana, CK or CC... Even with the +5 lower cup and the +7 race, my 36 still hit the DT on the Canfield... The new One has addressed this though (and I've since sold this bike)...
    YIKES!
    on my rfx, I only needed a millimeter or two. The +5 prolly a little too much but I'm still really happy with it.
    Thanks for that shot! I'm trying to correct a handling issue on my hardtail. It's a modern geo designed around 80-100mm forks. But I'm in love with my oldschool Marzozzhi Z2 Atombomb and it's short chassis and shorter 72mm travel. It's a perfect fork for the use, but handling is too twitchy and the ride suffers. The S3+5 is not enough. I put a huge tire on front and short tire in back and that helps a lot, but I'd rather not run that tire up front. The Ventana +7mm race might do the trick.
    Was your One never designed for SC forks?! That looks like a rather major oversight! One of the first 2-3 things that should be addressed in a frame drawing.
    just curious, how long did you run that set up before getting rid of the frame?
    Quote Originally Posted by Mr Tiles
    I only had the bike for a season. I sold it once I got the RFX. The new One design has way better dt clearance than my version and looks like it can take anything from a 36 to a Boxxer or 40.
    locked - time out
    Any reasoning on why it had no clearance?
    Quote Originally Posted by glitz
    The medium frames had better clearance. I'm guessing that the crown/dt clearance wasn't considered on the small frame.
