Results 1 to 32 of 32
    Ideal Reverb cable routing 2010 DW Spot
    Sorry for being a bit lazy and not trawling through the threads but just trying to fit a 125 Reverb dropper and not sure of best cable route - is there a consensus ideal routing?
    See: 2011 5 Spot set-ups posts #427 to 433. Sure there are other suggestions in other threads, I picked up the method I used somewhere deep down in the archives many moons ago...
    Thanks! I hadn't considered that one - I'll give it a go.
    If you have the hose length, the Mikosan method is really the cleanest. Last summer I rode with someone with that routing and when dropped put the loop well away from the linkage. My Reverb hose has been cut to fit under TT, so am stuck.
    GAME ON!
    i ran mine under the top tube and looped the cable under the main rocker bolt and up and then zip tied the hose to the top rear chainstay. i don't know if you can picture that in your head, but when the post is fully compressed, the loop was behind the rocker arm and contained to the small area between the seat stay and rocker arm.
    RIP Adam Yauch
    "M.C. for what I AM and do, the A is for Adam and the lyrics; true"
    Luckily I haven't had the snip yet, so will give the Mikkosan route a go. Thanks!
    on a routine expedition
    Reputation: Marshall Willanholly's Avatar
    Inspired by the Specialized DH team riders in Pietermaritzburg, I wound mine around the post. Keeps it far away from the linkages when compressed and doesn't compromise the function at all.
    Kiwi that Flew
    Reputation: deanopatoni's Avatar
    +1 for the Mikkosan route. Been running this for the last year with no issues. Visually it also compliments the rear derailer cable on the righthand side too.
    The other image (the dirty one) shows the post in its dropped position with the cable set to gently lay just above the aluminium bridge. (Sorry its not so clear).
    Regards
    deano
    PS - In case you where wondering, when the cable is run in this way are NO rub points anywhere.
    Attached Thumbnails Attached Thumbnails Ideal Reverb cable routing 2010 DW Spot-img_4880-2.jpg
    Kiwi that Flew
    Quote Originally Posted by empy View Post
    You may be lazy for not trawling but you get MAX respect for super clear thread title!
    If we all titled our threads like this, forum life would be a lot easier..
    So I've tried the Mikkosan route, but it looks like the cables going to catch the front mech collar on the way up. From your pic deanopatoni it looks like it would catch yours too. Am I missing something?
    Kiwi that Flew
    Good observation, but it doesn't catch in use. It is just pulled in tight in the photo as the kryptonite chainlock is pulling it in close to the frame.
    --- deanopatoni ---
    Reputation: Rey Recinto's Avatar
    Mar 2005
    I got away with this cable routing on my 5.Spot
    Attached Thumbnails Attached Thumbnails Ideal Reverb cable routing 2010 DW Spot-dsc09660.jpg
    Reputation: KRob's Avatar
    Quote Originally Posted by Rey Recinto View Post
    Yep, I used this same (simple routing on my 2010 5 Spot. Not super fancy but it worked fine: Moved freely, didn't catch on anything and was out of the way.
    Isaiah 58:14
    www.stuckinthespokes.com
    Reputation: Razorrazoo's Avatar
    Jul 2013
    I can't see half of the photos on this thread for some reason so they may hold the answer but I don't know.
    With the Mikkosan route does the hose thread between any of the linkages or is it attached to the seat tube in any way?
    I've tried to route my new one that way (but not threaded through anywhere, just down the seat tube using the supplied guide and then joining up with the rear brake cable) but it seems to push the cable towards the rear wheel where it catches.
    Hey Razzor,
    Nope, mine doesn't thread to any of the linkages. I placed the supplied cable guide on the seatube where it meets the top tube then turn it all the way to the left. Then I used the supplied cable clips to run it along the brake lines. It doesn't bunch up to the rear.
    Jul 2013
    Thanks Mikkosan, I'll have a play around with the hose guide, maybe I just need to position it a bit better as it sounds like the rest or the routing is as you have yours.
    Re: Ideal Reverb cable routing 2010 DW Spot
    Here's the only pic I have on my phone now.
    The first house guide is clipped on the brake cable right before the cable guide on the downtube.
    Hope this helps.
    Attached Thumbnails Attached Thumbnails Ideal Reverb cable routing 2010 DW Spot-uploadfromtaptalk1378995454231.jpg
    Jul 2013
    Those photos are ideal thanks. Looks like I have the guide set too high (I currently have it in the gap created by the seatube/toptube gussett (or whatever it's called). Hopefully won't need to do much more than move the guide. When the post is dropped where does the hose loop out too (to make sure I'm getting it right)?
    It loops downwards and just barely touches the DW Link pivot where the brake line is cable tied. You could barely make it out on the 2nd pic, but the cable it just above the DW link.
    Jul 2013
    Aha, I think I've got it, hadn't noticed that the seat was dropped in the second photo. Thanks for your help.
    Mar 2005
    [ATTACH=CONFIG]
    Ideal Reverb cable routing 2010 DW Spot-dsc09660.jpg831835[/ATTACH]
    here is how I routed the cable on my small 2013 5.Spot...
    Get a LEV!
    Jul 2013
    Too late for that!
    Think I have it sorted now, time will tell.
    yeah, sorry. I meant for those thinking about a new dropper, get a LEV.
    Jul 2013
    Would still be sort of sold on the none cable design of the reverb due to the uk winter mud. My old HiLo always felt like it would seize at any time.
    May 2012
    sorry guys just riding on this thread... would the reverb fit a 2007 5 spot frame?
    Reputation: rodel's Avatar
    Nope, reverbs not available in the correct seat post size.
    Your choices are limited... Good choice would be KS Lev
    Anytime. Anywhere.
    Reputation: Travis Bickle's Avatar
    You need a 27.2mm post. Gravity Dropper is a solid choice.
    I got some bad ideas in my head.
    May 2012
    damn! haha thanks guys ... now im stressed out haha its 27.2 because its an old body right...?
    May 2012
    Quote Originally Posted by Travis Bickle View Post
    thanks man for the exact diameter measurement... ill look into the brands now...
    Anytime. Anywhere.
    It's not the only one, you have options.
    Nov 2012
    5-spot - Album on Imgur
    I've been playing with cable routing for a while, finally happy with it (need a longer housing now though....)
    I put the dropper housing on the down-tube, and the rear derraileur housing on the top-tube where the front der. would have gone. I may re-route the rear der housing over the main pivot, but not sure yet, havn't had any issues so far.
    My bike MCA kinda climbs like a billy-goat. WOO WOO!
  1. Ideal Reverb Cable Routing - Hitting Rear Tire
    By stunzeed in forum All Mountain
    Last Post: 01-17-2013, 05:00 PM
  2. SX Trail Reverb Cable Routing
    By citizenlee in forum Specialized
    Last Post: 10-19-2012, 03:29 AM
  3. Endorphin reverb cable routing
    By jubilee in forum Knolly
    Last Post: 02-11-2012, 11:46 AM
  4. Cable routing for Rockshox Reverb on a Tracer
    By brenrub in forum Intense
    Last Post: 11-02-2011, 04:39 AM
  5. Reverb cable routing on Firebird?
    By istvisinet in forum Pivot Cycles
    Last Post: 03-06-2011, 01:38 AM
