    how heavy are you ??
    Reputation: Scottay5150's Avatar
    I have a 08' Spot
    And a LX crankset, 9 speed cassette, King hub. How many spacers am I supposed to use for correct chainline? How do I know what's correct?
    Scottay
    ride
    Reputation: ignazjr's Avatar
    Assuming that this is a newer, integrated bb LX crank, run 0 spacers on the left and one on the driveside of the bb shell. You'll probably need a thin metal washer between the cassette and the freehub, too.
    edit - I see you're in Highlands Ranch. Swing on by if you ever get up north here!
    Redstone Cyclery
    intense*transition*rocky mountain*turner
    web - tweet - FB
    Lyons, CO
    Surfin' da mountain
    Reputation: Cucucachu's Avatar
    Aug 2003
    Hey Scottay,
    I found that if you run a Shimano cassette on the King hub you will need a spacer, but if you run a SRAM cassette, you won't need the spacer. The SRAM cassette is ever so slightly wider.
    I'm not running any BB spacers either and not having any problems.
    Dave... ill be there again...
    Edit - I see you're in Highlands Ranch. Swing on by if you ever get up north here![/QUOTE]
    Thanks for the info.. Making the adjustments right now ... And I have been to your place in Lyons... Drove from the tech center to youe shop for a Tuesday night ride and started to get sick @ the shop... I will be back
    Scott
