Results 1 to 6 of 6
    Reputation: zonoskar's Avatar
    Howto remove pivot axle?
    Is there a special trick to it? If I loosen one bolt, te other side won't come off as the a xle spins with the bolt. Howto remove the axles on my 2002 RFX?
    BBW
    BBW is offline
    Reputation: BBW's Avatar
    I would stick something in the axle to prevent it from rotating; some stick made out of wood or plastic. An old toothbrush works, just modify it with a knife to fit the axle ;-)
    BBW. MS, RD
    Newer Turner pivot axles are keyed for an Allen wrench to prevent spinning while removing the bolt. I don't recall what size Allen wrench is required. I also do not know if 2002 pivot axles are keyed like modern axles. I'll bet they are.
    Reputation: gmats's Avatar
    Apr 2005
    Using the two torx bits, loosen and remove one of the bolts. After that, stick in a 6mm allen wrench into the hole and hold it in place (leverage) with a box wrench. Now you should be able to remove the 2nd bolt.
    I just got word from Greg at Turner that says 11 lb-ft on the main pivot bolts, no matter the vintage. I just recently snapped one trying to torque to 17 lb-ft.
    beer is good
    Reputation: Nels's Avatar
    6mm allen key fits inside of pivot shaft...
    Steve
    "looking California, feeling Minnesota"
    Thanks for the pointers. I'll check this evening.
    /edit: It worked!
  1. Replies: 0
    Last Post: 11-17-2012, 02:51 AM
  2. Unable to remove axle
    By naiku in forum Beginner's Corner
    Last Post: 09-05-2012, 12:29 PM
  3. How to remove thru axle?
    By jon777 in forum Foes
    Last Post: 07-12-2012, 07:06 PM
  4. how to remove this kind of axle?
    By engrmariano in forum Wheels and Tires
    Last Post: 01-15-2012, 08:49 PM
  5. How to remove pivot axle from Wildcard?
    By jjom in forum Banshee Bikes
    Last Post: 06-06-2011, 01:24 PM
