Results 1 to 9 of 9
    how much travel is my spot getting really?
    It just dawned on me that If I buy a 5 inch travel bike I am really only getting a 4" or 4.5" travel bike because of sag.....right? so if I really wanted a full 5" of usable travel I should have gotten a 6" travel bike.....right?
    my romic measures almost eggzactly 7.5" i2i and I have it set up so it sags .5" when I sit down on it. ( from 7.5" i2i to 7" i2i) my shock stroke is about 2" how am I supposed to know how much of my 5 inch travel am I using up when my romic sags .5"? I feel cheated.
    No, that's not phonetic
    Reputation: tscheezy's Avatar
    Don't run any sag. There, you have a full, measured, 5 inches.
    My video techniques can be found in this thread.
    Tonight we ride.
    Reputation: fonseca's Avatar
    Quote Originally Posted by tony0643
    You're still using the full 5". When you ride over depressions on the trail, your suspension extends to "fill" the holes and keep your ride smooth. So you're not cheated of travel, think of it as negative travel.
    Quote Originally Posted by fonseca
    Right...thats what the rebound is for , to make sure the shock extends fast enough when compressed to bring it back to full extension giving you the full amount of travel.......i think... it was explained to me once before from chris @ titus..made sense just dont know how to word like he did
    Toby Wong?
    Reputation: Tappoix's Avatar
    oh please.
    Lay off the Levers
    Reputation: Bikezilla's Avatar
    I believe Giant makes a bike that runs with out sag. It pedals great, bob free. But I've read that it is at the expense of some plushness and small bump sensitivity.
    Sag is good, most vehicular suspention systems use it. It not only fills the gap on uneven ground, it extends during drops and launches, and then you are using the full 5".
    Ever see those nasty off road truck races? when those monsters launch, their wheels droop about a foot(or more), and when they hit the ground they land like a wet sponge...it's a beautiful thing to watch. That's what sag is doing for you.
    Faster is better, even when it's not.
    Tonight we ride.
    Quote Originally Posted by Tappoix
    oh please.
    Say pretty please with sugar on top.
    Reputation: Scott@GO-RIDE.com's Avatar
    Sag is very important for a good riding trail bike. Without sag your suspension would skip across rough sections of trail much more then with sag. It also helps bikes track the ground when braking. On a 5" bike sag would normally be set about 25% to 30% or about 1/2" to 5/8" of shock travel.
    If you really want a bike that has 5" of positive travel after sag, you will need to step up to about a 7" bike. 30% sag on a 7" bike will leave you with about 5" of remaining travel. Keep in mind that the more travel you have usually the greater % goes to sag. Example: 4" bike runs 20% - 25% and a 9" bike runs 35% to 40%.
    Pivot Firebird
    Hightower 29
    Tallboy 3
    Pivot LES SS
    Salsa Beargrease C
    Giant TCX
    Reputation: esquire's Avatar
    Yup, correct
    Quote Originally Posted by Bikezilla
    You are correct sir, its called the NRS, and it is rough on small bumps, but does climb quite well. Rode one for a summer a few years back when they came out. Nice bikes, good price, just rough without the sag.
  1. panic attack! 5 spot longevity and paranoia!
    By tony0643 in forum Turner
    Last Post: 05-06-2004, 11:22 AM
  2. Marz MX Comp not getting full travel? take some oil out.
    By phil. in forum Shocks and Suspension
    Last Post: 03-30-2004, 02:33 PM
  3. How much travel does your fork really get?
    By Structure in forum Shocks and Suspension
    Last Post: 02-14-2004, 07:02 PM
  4. mxc travel adjustment?
    By dompedro3 in forum Shocks and Suspension
    Last Post: 01-26-2004, 04:06 PM
  5. Replies: 4
    Last Post: 01-22-2004, 12:09 PM
