Results 1 to 17 of 17
    Reputation: Rollin'in'Zona's Avatar
    New question here. How much drop can a 5 Spot take?
    I've been drooling over the 5 Spot, but wondering if I need longer travel. I thrive on long technical rocky trails (that's all we have here) but the opportunity for 3' to 4' drops are numerous, and I'm finding myself drawn more and more to this light free-ride stuff.
    Locally, a 5" fs bike is considered the minimum for XC.
    Most of my friends ride 7"-8" travel frames in the 45lb range (and huck 10 footers like I do 2 footers) but I'm much more of a trail rider than they - #1 for me is tech trail and I don't really want to push a 7" travel bike around, but would like to take part in the 3'-4' drops.
    So if the 5 Spot can handle 4' drops with a 165lb rider, weeeeeheee!
    What do y'all think?
    wait a minute....
    Reputation: SIGMA's Avatar
    i have taken several 2-3 foot drops on mine and it does fine. i am 180 lbs and have only had it for a few weeks so i dont know about long term. i do know that the frame has a great reputation but i have read some complaints about the romic. so far so good with mine.i think it would hold up to 4 or 5 feet if i get bigger balls.
    FM
    FM is offline
    Reputation: FM's Avatar
    Apr 2003
    I'm sure the 5-spot can take tons of 4" drops to flat no problem, if executed smoothly... and much bigger if there's a good tranny. How many it can take is a separate question.... allthough I'm sure it would fair very well against other manufacturers similar frames.
    The thing is, once you get the hang of drops of that size, you'll probably end up hitting them every chance you get, and always watching for drops that are 6" bigger than the last one you conquered.
    I guess it's all about prioritizing. allthough I'm no wade simmons, I can say that a bigger bike will definately safely encourage you to go bigger than you would on a trail-bike like the 5-spot. If you do decide that sounds like more fun than being first to the summit of every climb, you won't be dissapointed with a heavier bike, even while climbing. a little fitness work goes a long way, towards making up for a heavier bike. Plus, if you're friends are already riding heavier FR bikes, riding the same will only help you hit what they're hitting.
    Basically, the 5-spot can take just about anything with the right pilot. But have no doubt that a heavier, longer travel bike will have you landing bigger drops sooner, and safer. I would definately suggest a RFX if they were available. But, since they aren't, consider a azonic saber. It's right in between the RFX and a 5-spot, 8.5lbs I think, 4-bar, romic, and either 5" or 6" of travel. Pair one up with a Z150 and you'll have a hell of a bike for drops, FR *AND* XC riding.
    Mashers Only!!
    Reputation: HUGH's Avatar
    Baby steps!!!
    I just started doing drops since I got my spot. I'm 200 lbs ish and it did great.
    HUGH
    Reputation: Duncan's Avatar
    cool picture
    Quote Originally Posted by HUGH
    HUGH
    That's a very cool picture
    GSS
    GSS is offline
    I'm no monster hucker but have done quite a few drops on my 5spot. As people have mentioned above, it's all about how smooth you are. There's no magic height/drop that the 5 Spot is going to suddenly fail at. Obviously, repeated drops are going to start to fatigue the frame but I would say the 5 spot would have no problems with regular 4 foot drops as longs as the landing it not too flat and you are not too harsh.
    If you want to start doing 10' drops regularly like your friends, then the 5 Spot is not the frame for you.
    I've done this drop on my 5 Spot a few times without problems - even my TALAS forks enjoy it! (note this pic is not me).
    Is that England?
    Is that photo in England? If so, where? How much of a drop is it? (I guess it's going to depend on your speed)
    GSS
    GSS is offline
    Yea, the drop is at Chicksands near Bedford. Theres loads of great freeride stuff there including a dual course.
    The drop is around 6-7 ft at the point I landed (at a guess), the transition keeps going for a while so with enough speed you could get up to about 12ft, probably more. Theres plenty of bigger stuff there as well if you are that way inclined.
    FM
    FM is offline
    Apr 2003
    Great pictures!
    I'd say this- I think once you have the basics of doing a 2' wheelie drop, or coasting off a 2' ledge, you have most all the skills required to go much bigger. It's just a matter of working your way up to the bigger ones to gain confidence and experience, but they're really not much harder.... However if you buy a bike that wasn't designed for drops, you're going to have durability issues. It makes an extra pound on a frame seem like a small price to pay.
    And travel- you don't really need any travel in back if you keep your knees bent to absorb the landing. However a bigger fork will really save your bacon should you land front-wheel first.
    Quote Originally Posted by GSS
    Quote Originally Posted by FM
    I don't know, it might be pusing it taking a 5 spot off of 4 inch drops to flat.
    FM
    FM is offline
    Apr 2003
    Ha! Good catch! I was tired and drunk when I wrote that, after a great, long spring ride.
    Obviously, I meant...... 4-1/2"!!!!!!
    Quote Originally Posted by CDMC
    Reputation: mattogu's Avatar
    PM me for a movie of me dropping this.matt
    Good job!
    I guess it's all about prioritizing. a little fitness work goes a long way, towards making up for a heavier bike.
    Thanks for the excellent feedback - I really appreciate the suggestion of an alternate bike - the Azonic Saber. (I've also considered the Ellsworth Joker
    Thanks again.
    not sure if this link will work but here go's.It's a movie of a drop on 5 spot.I had posted a pic in this thread of me stand next to it.enjoy.http://www.imagestation.com/album/?i...47&mode=invite
    Reputation: schlitz's Avatar
    the 5 spot can take some serious abuse. if there is a decent tranny it can hadle 8-10 footers, but if its relatively flat then i would keep it under 6 feet. essentaily it all comes down to your shock set up and what kind of a rider you are. E.C. seems to beat the **** out of his and it handles it...
    Inspiring
    Cool
    I did a 1.5 drop yesterday on my 5 Spot. Its just getting that confidence back...
    Reputation: I_8_It_up's Avatar
    Quote Originally Posted by mattogu
    Looks fun!
  1. Romic or Swinger 4way coil for 5 Spot
    By Alpenglow in forum Turner
    Last Post: 05-19-2004, 06:20 PM
  2. Owned 5 Spot and Maverick? If so, I have questions.
    By Count Zero in forum Maverick
    Last Post: 05-15-2004, 09:14 AM
  3. Another New 5 Spot Story
    By Surfer in forum Turner
    Last Post: 03-22-2004, 01:57 AM
  4. 5 Spot - first ride, some thoughts
    By cooldaddy in forum Turner
    Last Post: 03-09-2004, 12:09 PM
  5. finally appreciating the 5 Spot
    By Duncan in forum Turner
    Last Post: 03-01-2004, 06:47 PM
