Results 1 to 3 of 3
    Help with how to set up Romic ?
    Got my new 5 Spot but have no clue how to set up the Romic. I weight 180, can anyone help? By the way, bike is mostly xt with Talas RL, weighs about 27.5.
    M070R-M0U7H FR3NCHI3
    Reputation: Acadian's Avatar
    you got a manual with that Romic shock?
    if now download one online at www.romicmfg.com
    1) check your sag to make sure you have the right spring
    2) set compression and rebound
    3) off you go!!
    Ouch, I am hot!
    Reputation: Dirdir's Avatar
    Try This Too and I need Help Too
    Quote Originally Posted by arc1
    This cite has also been set forth as helpful.
    http://www.transitionbikes.com/RomicSetup.cfm
    However, because I am such a doofus, I can't do any of it right. Can't even change my spring, etc. The Romic manual is only somewhat helpful. I have some questions too. Is there a torque setting for the bolts to attach the shock to the frame? Should I care about this? When installing a new spring, how/where do I start at zero preload? It says no more than three turns of preload, but where do I begin?
  1. Coil Springs for Romic Shocks
    By bcjoker04 in forum Shocks and Suspension
    Last Post: 11-30-2004, 08:12 PM
  2. Shock - PUSH re-valve or Romic
    By Lee W. in forum Downhill - Freeride
    Last Post: 03-31-2004, 03:25 PM
  3. Romic Reliability?
    By forester in forum Shocks and Suspension
    Last Post: 03-02-2004, 01:31 AM
  4. bullit & romic...paging keefe (and others)
    By oli_f in forum Santa Cruz
    Last Post: 02-22-2004, 04:29 PM
  5. Romic vs. Mojo-tuned Fox Vanilla RC
    By NorseRider in forum Turner
    Last Post: 02-20-2004, 01:22 PM
