Results 1 to 8 of 8
Thread: Grease zerk
    Grease zerk
    I have a grease zerk that keeps popping out. any ideas?
    Reputation: CrashTheDOG's Avatar
    This should answer your question and is must-read material for all Turner owners.
    Lay off the Levers
    Reputation: Bikezilla's Avatar
    Quote Originally Posted by tocoldmn
    Clean it, and the hole it goes into as best you can and tap it in with a hammer. If it still fits loosely, ask for a replacement from Turner. I had one fall out on the trail once. They got me a replacement quite quickly. Chances are the new one will fit much more snugly. At least it did for me...and try to resist pumping the grease too hard.
    Faster is better, even when it's not.
    No, that's not phonetic
    Reputation: tscheezy's Avatar
    I either loctite or JB Weld epoxy them in if they pop out. I wish they were threaded in or something. I launch them occasionally. Once they pop out a few times, they seem to get more slippery due to being compressed. Only glue will hold them then.
    My video techniques can be found in this thread.
    Rides like wrecking ball
    Reputation: Bulldog's Avatar
    Quote Originally Posted by Bikezilla
    I had one new one that popped right back out. After I learned the horst pivots don't actually accept grease easily I just said F-it and tapped it in, but it's always made me nervous about it just falling out. It comes right out every time I try to grease that pivot. Some random, semi-permanent adhesive will be used next time I actually give the bike some love and attention.
    Quote Originally Posted by Hesh to Steel
    With people liking mongoose and trek bikes now, what's next in this crazy world? People disliking the bottlerocket?!
    Put a thin layer only on the neck of the zerk before pushing it in. That way none gets "ahead" of zerk where it could end up inside the pivot. If you rough the neck of the zerk up a bit, and clean the hole out with a paper towel and q-tip with a bit of alcohol, you only need a tiny bit of JB weld.
    Quote Originally Posted by tscheezy
    How do you prevent the loctite or JB Weld from pluggin the hole the grease is supposed to move through?
    Roy
    Roy is offline
    Reputation: Roy's Avatar
    Quote Originally Posted by CrashTheDOG
    If you use Tcheezy's method, you only get the JB Weld on the "collar" of the zerk. The rest of the zerk is well inside the chamber so nothing ever gets plugged.
    The same effect can be had if you put a bit of the adhesive on the frame around the hole. This where the "collar" seats and you can just clean the rest with alcohol/swab as mentioned.
  1. Replies: 2
    Last Post: 08-19-2012, 02:15 PM
  2. What to grease on lower shaft assembly?
    By ian flux in forum Shocks and Suspension
    Last Post: 04-09-2004, 07:43 PM
  3. to grease or not to grease
    By chirider990 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-04-2004, 11:07 PM
  4. To grease, anti-seize or loctite? (BB)
    By Locoman in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-10-2004, 04:52 PM
  5. To grease, anti-seize or loctite?
    By Locoman in forum General Discussion
    Last Post: 03-10-2004, 10:00 AM
