    Getting more weight over the front wheel.
    Since fitting my Pike 454 I feel as though I need more weight over the front. I'm running a 90mm thomson 5 degree rise stem and a straight seatpost. Have moved the saddle a bit further forward but would a longer stem also help?
    MK_
    MK_ is offline
    carpe maņana
    Reputation: MK_'s Avatar
    Quote Originally Posted by Robbz
    Longer stem would definatelly help, but it will hurt on the downs. Just work with your body, seat on the nose of the saddle when you pedal, lower your torso, get your butt off the saddle on the really tough parts of the climb.
    _MK
    Before you diagnose yourself with depression or low self-esteem, first make sure that you are not just surrounded by a*holes
    Amphibious Technologies
    Reputation: SCUBAPRO's Avatar
    Try these: a low rise bar, 0 degree rise stem, and/or lower bar to floor height (achieved by decreasing number of stem spacers or not using any)....
    "The best you've ridden is the best you know" - Paul Thede, Race Tech
    Lay off the Levers
    Reputation: Bikezilla's Avatar
    Strap a box of KrispyKremes to the bars. That usually does the trick for me.
    Seriously I found the handling of my bike very different going from an AM1 to a 454DA I'm still trying to get it dialed myself.
    Faster is better, even when it's not.
