Results 1 to 35 of 35
    rr
    rr is offline
    I don't do PC
    Reputation: rr's Avatar
    Front end upgrade/SEMI bling
    Got the Domain on, will do a tester tomm., feels nice so far, compared to the Z1FR1 I had on there it's bigger/stiffer, more travel, adj travel, adj compression, and the Maxle. Gained 1/2lb or so with the fork/stem but hell, at around 37 pounds who cares , and the steel stanchions go well with the silver rear too!
    pic1- Domain
    pic2- new stem/ Easton Vise
    pic3- RFX looking gooood
    pic4- playing with the new scale/ 37.3lbs
    pic5- weighed the Burner for fun, under 29, yeah!
    Outcast
    Reputation: Renegade's Avatar
    Rick, is that the 318, or the 302?
    And, is it stuck down yet?
    rr
    rr is offline
    I don't do PC
    Quote Originally Posted by Renegade
    It's the 318, Motion control and U-Turn, and COIL so no stuck down, it just blows thru the travel over every pebble in the trail, hey at least it's plush!
    No, that's not phonetic
    Reputation: tscheezy's Avatar
    Looks cool. I will be curious to hear the report. IThere was nothing about the coil RS's of the past few years that made me think I wanted one. In fact you would have to pry my 06 66SL from my cold, dead fing.....
    ....oooooooooohhhhhhh! Is that an 07 66SL ATA I see.......?
    My video techniques can be found in this thread.
    Outcast
    Quote Originally Posted by tscheezy
    Poseur! It looks like you put white lowers on your '06. Who are you trying to fool?
    After I glue an ATA knob on top of my 06, I'll fool everyone!!
    Reputation: CrashTheDOG's Avatar
    Quote Originally Posted by rroeder
    Nice! An RFX that even that schizo Gonzo-Article-Pablo could be proud of Now get your arse back to St. George and put it to good use.
    Bite Me.
    Reputation: cutthroat's Avatar
    I'm sure you could get that thing heavier if you really tried.
    When I see an adult on a bicycle, I do not despair for the future of the human race. ~H.G. Wells
    rr
    rr is offline
    I don't do PC
    The Domain is the antibling, I'm such a non conformist
    Ron- I will be back there next year I bet, the wifey wants to go back and hike in Zion, and we want to see Bryce also, I will schedule a couple days to ride for sure!
    Bodhisattva
    Reputation: The Squeaky Wheel's Avatar
    Quote Originally Posted by cutthroat
    Fo could give you some tips
    Negative Rep Points!!!!
    Reputation: Aquaholic's Avatar
    Wheezy, are you getting fellatio from the Marz girls or what? There is something comically hypocritical about you discussing irony in the case of Slo Fizzle, especially using phrasing that happens to describe YOU to T.
    "He needed the 6-Pack and the Homer Nation's approval".
    GMAFB
    What the EFF is "All MOUNTAIN"???
    rr
    rr is offline
    I don't do PC
    I will be reversing this trend though with a new set of wheels soon, the Sun Ringle tanks will be for shuttle/Keystone days, I bet I could shave close to a pound with some durable trail wheels for some of our rides.
    Bite Me.
    Hold on there Hoss - I've got an as new set of Dual Dutys (the 30mm variety) with 2.4 Motoraptors, WTB Speed Disc Hubs, 8" front rotor and spanking clean 11-34 LX cassette that you could throw on that thing - I think the total weight of the entire set up is only around 12.5lbs - you could probably get over 40lbs total on the RFX and give FO
    a run for his money - think about it I'll be riding the Anatrim 5 Spot tomorrow at Red Hill - I think she's back down near 30lbs again
    rr
    rr is offline
    I don't do PC
    Now that I have a scale I'm gonna weigh these wheels and see what I can do to build up a lighter yet durable wheelset, I really wanted to spend the coin on the wheels but the Z1 was not cutting it.
    How about the Burner, I fiqured it was closer to 30! I love that bike
    Quote Originally Posted by Aquaholic
    Blah blah blah
    Ok, you lost me there.
    rr
    rr is offline
    I don't do PC
    One more bit I put on
    rr
    rr is offline
    I don't do PC
    Got in a good test ride yesterday, first of all, the bike felt balanced front to rear like never before, I'm actually getting proper sag which I never was able to achieve with the Z1, even with zero air in the PAR.
    Certainly did not notice the extra 1/3lb, but I did notice the added stiffness! The front end tracked straight thru the rockgardens and just felt smoother with the improved suspension. The stock spring seems to be right but I will reserve judgement till later once I do some RFX worthy rides and the fork breaks in, this was more of a standard trail ride and one I do on the Burner most of the time, however, I did not notice a too linear feel like some have mentioned.
    With the added sag, I found I liked it at the full 160mm setting most of the time, when I lowered it to 150mm the front end felt steeper than with the Z1, probably the same A>C but again, more sag. I stopped and lowered it fully for a short steep hill and zipped right up it, usually had to fight the front end a little with the Z1, can't wait to tackle the first big hill with the travel adjust.
    I also played with the compression adj a little, when cranked up I could feel the fork riding a little higher in it's travel but a bit too harsh feeling over chunky terrain at speed, I ran it 3(out of 10) clicks IN most of the time. Nice fork, and I'm very pleased with the initial ride.
    Neg reppers r my biatches
    Reputation: FoShizzle's Avatar
    Quote Originally Posted by The Squeaky Wheel
    no way man....he definitely has me beat...though at second glance, perhaps not...nah, i doubt it.
    Outcast
    Nice headset cap Rick. I'm afraid that if I put one of those on my bike, I would try to drink my steer tube, and it would taste too bitter.
    So how about an update; is your fork stuck down yet?
    Baked Alaskan
    Reputation: AK Chris's Avatar
    RR - sweet ride, love the topcap. Funny how everyone seems to pick up weight as time goes on - and I'm not just talking about the spare tire. Ignore Renegade and the stuck down comments, I think he's just jealous of the Ano green. Plus he seems to be more receptive to pics with the ride in front of or on a couch. I think if you took it into the living room and snapped another pic, he'll start gushing about your ride.
    The red couch has moved from Alaska to Florida...
    Outcast
    Lean a scantily clad, well endowed mega-babe next to the bike, then I'll be jealous!
    Baked Alaskan
    Oh come on...
    Are you sure...
    Outcast
    Sorry, without the bimbo, you won't get a rise out of me.
    rr
    rr is offline
    I don't do PC
    Hot bike! look at that tight rear end and big round.......stanchions
    No stuck down, since I'm a real man and run COIL suspension on my manly RFX I don't have to worry about those pansy XCish air suspension issues. How about yours?, it's been a few weeks so your due for an oil change right? Bushing overhaul perhaps??
    Outcast
    well, I do have a light popping like feel to the initial compression stroke.....probably related to NOT knowing to put more air in the PAR chamber than you do in the negative chamber. Seems marzocchi forgot to put that factoid in the owners manual. But other than that, it works well. Maybe I just need to burp the cartridge. Better bring home extra beer for that procedure.
    rr
    rr is offline
    I don't do PC
    Yeah, the manual does leave a little to be desired, I would of been lost if not for the Zoke homers. Does the fork use the bladder system, ala TST?
    Outcast
    nope. I read somewhere a month or so ago that the '07 sl was going to have a bladder system, but that is not so. The rc2 cartridge is identical to the '06 model. The ata feature is very cool though. I dial the bike down to 140mm for the climbs, dial it up to 180mm for the descents. If the terrain is more rolly-pollie I leave it set at 150mm.
    what travel would you recommend for pulling trail a bikes....sometimes with 2 kids as well?
    Outcast
    Fo' I would be speculating, as I have no rug-rats of my own, other than my two amazon parrots, who prefer I set my fork at 180mm. Perhaps SSINGA can give you some sound advice on this matter, he being an experienced trail a bike pilot.
    yeah...I am thinking 180mm as sometimes the kids like me to go off curbs when i feel like being real aggro.
    FleshwoundGravityResearch
    Reputation: mtn hack's Avatar
    I think ssinga knows that answer.
    rr
    rr is offline
    I don't do PC
    The A>C is 565 at 180mm, thats some serious chopperage for our model RFX Fo, better save that setting for those more extreme gravel paths.
    Seriously, I want to see the chopperness at 180mm when you get your rig, mine looks slack at 160mm, 545 A>C I think.
    yeah whatever.....dude, i am hardcore so a chopper suits me. I am thinking about getting some tats as well to look even badder asss at the trailhead, or the park with the kids...just need to decide on a design.
    Just roll it......
    Reputation: ebxtreme's Avatar
    Quote Originally Posted by FoShizzle
    I am thinking about getting some tats as well ..just need to decide on a design.
    Don't you mean "which tribe", Fo?
    I was extremely surprised that running my '07 66 SL fully extended at 180mm didn't make the front end completely floppy. In fact the first few rides it didn't even dawn on me that I had raked out the front end, but after seeing how convenient the ATA feature is I'm constantly adjusting the travel mid ride.
