Results 1 to 5 of 5
    Reputation: oxygenrace's Avatar
    New question here. Front Derailleur for Burner Question.
    I know the size (34.9) but does the burner need a top-swing or dual pull front derailleur? What are people currently using? Here are some options i have seen on online retailler pages:
    Deore XT M761 28.6/31.8/34.9 Dual Pull/B
    Deore XT M760 28.6/31.8/34.9 Dual Pull/T
    Deore XT M760-E TypeDual Pull/Top Swing
    XTR M960 Top-Swing Dual-Pull 35.0 Frt De
    XTR M961 Trad Dual Pull35.0mm Front Der
    No, that's not phonetic
    Reputation: tscheezy's Avatar
    Either of these:
    You do NOT want an "E-type" or top swing. You need a bottom swing (B?), top (or dual) pull. I am thinking that "trad" means bottom swing, but I'm not positive. Don't get an expensive front der. Just get LX or XT. There really is no functional difference between the grades.
    My video techniques can be found in this thread.
    M070R-M0U7H FR3NCHI3
    Reputation: Acadian's Avatar
    I assume the Burner and 5-Spot take the same front derailleur?
    will a FD-M738 work on a 5-spot?
    As far as I know, all recent Turners which accept front derailleurs (e.g., O2, XCE, RFX, 5-Spot, Burner) use the same front der. The 738 in a 31.8mm (1 1/4") will fit. I wonder if that is an old 8-speed front der? The 8sp front ders are 0.5mm wider in the cage than 9sp. If anything, that should reduce chain rub. I don't see why it wouldn't work.
    Quote Originally Posted by tscheezy
    ya it's a 8spd one...should work I guess!!
  1. Need advice w/XT front derailleur....arrggghh!!!
    By headlands in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-03-2011, 05:10 AM
  2. Sram 9.0 front derailleur adjustment?
    By mikeyjunior in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-07-2004, 10:56 AM
  3. Front Derailleur for Spider
    By FR Wannabe in forum Intense
    Last Post: 03-21-2004, 05:18 PM
  4. front derailleur adjustment question
    By KSC in forum Tooltime
    Last Post: 03-19-2004, 07:27 AM
  5. Where to mount front derailleur on an 02 AC2
    By slow_spoke in forum Giant
    Last Post: 03-10-2004, 09:02 PM
