Results 1 to 11 of 11
    front deraileur question
    I know this has been asked 4,000,000 times and I apologize, but can I cut the piece that interferes with the rear triangle of this RD from my Kona Dawg. Or do I have to buy a new one for my 2013 5 Spot?
    34.9mm band clamp, down swing cage, and top route cable
    Thanks!!!
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by spicolli1976 View Post
    Thanks!!!
    http://www.turnerbikes.com/all-turne...-fivespot-faqs
    http://www.turnerbikes.com/turner-pd...h_frdermod.pdf
    mtbtires.com
    Thanks!!!
    Oaktown Honkey on Strava
    Another question. I switched 2 x 10 big ring from 38 to 34. Now that the big ring (34 tooth) is smaller, I should lower my front derailler. Unfortunately, the welds on frame will not allow me to lower. Any suggestions? 12mm gap from chainring teeth to Btm of derailler, should be 1 to 3 mm!
    Downieville dirt from rain on Sunday
    I have been riding my Sultan for a year now with a similar gap and no issues - I say run it and don't worry about it.
    Yeah, that 34 ring is best mod for where I ride, has not been a problem for 10 rides. However, when riding a little more hardcore on Butcher Ranch Trail in Downieville, chain comes off every run on that section of trail. No big deal. Just obsessing. I do the old front downshift, and try to get it back on while coasting. Baby pedal.
    So, second trip to Downieville in 10 days ( MTBR group was great ), the issue with this gap is that when on long smooth single track at high speed with small jumps, the chain will come off once in a while. Usually I can soft pedal, shift to small chainring, and get it back on without looking, and keep going. It BARELY comes off. Would be sweet to fix this gap.
    1. E-type derailler, never had one. Look delicate and flimsy?
    2. Different brand, with higher clamp.
    3. Direct mount to frame, but no female hole in seat tube.
    Any ideas?
    Ordered bolt on front derailler, and the adapter to fasten around seat tube, this adapter can be be dremmeled a bit. Also, the oval bolt hole on derailler can be drilled another 2 mm. Parts on order, we will see. My right crank is demolished from chain drops.
    Better now, direct mount dérailleur, and adapter. Thanks Wrench Science!
    Anyone need used front 10 speed Derailleur, modification already done, 55 hours old
  1. Front Deraileur huh?
    By pattongb in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-13-2012, 03:56 PM
  2. 07 Epic Front Deraileur Problem
    By illini in forum Specialized
    Last Post: 12-15-2011, 05:09 PM
  3. front deraileur tube dia.
    By weightweenie in forum Motobecane
    Last Post: 08-30-2011, 05:48 AM
  4. Tracer VP front deraileur
    By pvflyer in forum Intense
    Last Post: 06-28-2011, 03:55 PM
  5. '11 575 Front Deraileur XT/XTR
    By melibokus in forum Yeti
    Last Post: 05-18-2011, 08:26 PM
