Results 1 to 5 of 5
    Reputation: cowens677's Avatar
    front der for rfx
    I was just finishing my build last night and I went to put on the front der and I am pretty sure it will not work. It is a sram
    X7 low clamp top pull. Will this work or do I need the high clamp?
    Reputation: protocol_droid's Avatar
    The low clamp hits the lower shock mount, right. That's why the higher clamp is needed.
    3po armorless, the first weight weenie.
    MK_
    MK_ is offline
    carpe maņana
    Reputation: MK_'s Avatar
    I highly recommend the Shimano SLX for double ring setup. You need high clamp.
    _MK
    Before you diagnose yourself with depression or low self-esteem, first make sure that you are not just surrounded by a*holes
    I was sure I needed a high clamp but I just wanted to be certain. Tha
    nks, looks like I need to spend more money, where Is my obama bicycle stimulus package!
    Captain Underpants
    Reputation: Random Drivel's Avatar
    Like Keen sed, one of these will do the trick:
    <a href="http://picasaweb.google.com/lh/photo/rzVtBZmK2DlZILQ4RHAgLA?authkey=ZpyqiV6maZ4&feat=em bedwebsite"><img src="http://lh6.ggpht.com/_bzCP3imNsLU/SLxc2qEbgYI/AAAAAAAAA5I/Dysrl0erhbU/s800/DSC00156.JPG" /></a>
