Results 1 to 6 of 6
    Feb 2006
    Flux rear on spot?
    Anyone tried a 08 Flux rear on a 08 Spot front. And if so did it change the head tube angle?
    Reputation: DireWolf's Avatar
    The Spot shown in this thread has a Flux rear:
    1x9 Setups
    PM shootz, I'm sure he'd be happy to tell you more about it.
    MK_
    MK_ is offline
    carpe maņana
    Reputation: MK_'s Avatar
    My wife's 08 Spot has a Flux rear triangle on it. It never had a 5 Spot one, so I don't have a reference, but I know the chainstay is about an 1/8th of an in shorter. It is also about 0.35lbs lighter.
    Based on the info I got from the person who sold me the frame, the geometry was unaffected, with exception of the shorter chainstay, that is.
    _MK
    Before you diagnose yourself with depression or low self-esteem, first make sure that you are not just surrounded by a*holes
    Pixie Dust Addict
    Christina (DT's wife) was running a Flux rear on her 08 Spot. Not sure if there were any geometry changes.
    Not sure about 08, but I used to sell Turners extensively, and in the Horst Link years they shared the exact same rear end.
    Reputation: nybike1971's Avatar
    Quote Originally Posted by Grizzle
    Flux and Spot rear triangles were the same until (and including) 2006. In 2007 and 2008 the Spot and RFX shared a new asymmetric rear triangle. 2006 and 2007 Flux rear triangles are identical, but the 2008 Flux rear triangle changed to asymmetric design and lighter (ex-Nitrous rear triangle).
