Results 1 to 22 of 22
    Reputation: tductape's Avatar
    Flux pedal strike.
    Pedal strike.
    I have never had this issue on any other steed I have spent a lot of time on ( except the stokers pedals on my Mtb. tandem, but thats different). Frustrated, it is probably time to move on to a different frame. Yes, the sag is set proper. Enjoy the way it rides in all other ways but time to find something with a higher BB.
    Seek: Koski Trailmaster. Breezer Series 2 or 3. Cunningham Racer.
    Turner's geometry lists BB height @ 12.8" on a 120mm travel bike - would be @ least 3/4" too low for my riding preferances. I demo'd an older Specialized FSR that had a 13" BB height and hit the pedals left & right. Dealer @ the demo session told mne I needed to "time" my pedals better. I told him I have better things to focus on than absolute optimum pedal position.
    Reputation: Vespasianus's Avatar
    Can I ask how big you are?
    On MTBR, the reputation is infamous.
    6'3" 225 fairly agressive rider.
    Quote Originally Posted by tductape View Post
    I think the pedal strikes are partly associated with the dw link. I say that because as a big guy myself (6"1, 200), I find I get a lot of pedal strikes on my spot. MY BB is close to 13.6" (similar to my other bikes) but I still hit my pedals a lot more than I am used to. I think it is because of the the shock moving deeply into the travel over relatively minor things.
    A 650B front wheel will lift you up a bit, and in my experience, a bit matters a lot when it comes to BB heights. Several people I know like what it does to the Flux in terms of handling, too, including at least one Turner guy and my wife.
    Be thankful you don't have one of those new Specialized Enduros with 155 travel and a 13 inch BB. I think Shimano paid the designers in order to pump up pedal sales!
    Finally, there are a few well-reviewed flat pedals available now that are considerably thinner than the ones you are sporting.
    Whining is not a strategy.
    Pedal strike.
    I agree, you do need a new bike....a DW Sultan! The bigger wheels will suit you better in a variety of ways, not to mention reducing pedal strikes.
    jrm
    jrm is offline
    Reputation: jrm's Avatar
    What size frame?
    Over the Hill
    Reputation: dstepper's Avatar
    If it is a compromise between low bottom bracket or going over the bars..I will take the pedal strikes.
    Do you think it could be related to lack of mid-stroke support in your rear shock?
    I have a 2008 Turner Flux (with the TNT rear suspension). When I first started to ride it (3 years ago as I bought the frame used), I had a LOT of pedal strikes. It has a listed 12.8" bottom bracket. It's funny, but as time has gone by, I almost never strike my pedal. I just naturally adjust for it when going over objects by timing my pedaling. I don't even think about doing it. On the other hand, I like the low center of gravity when railing the corners and at high speeds.
    jfb
    jfb is offline
    Feb 2005
    southacres, it's exactly the same for me: natural adjustment without thinking about it after a few rides, but with a DW FLux...
    Quote Originally Posted by wheatgerm View Post
    It is and that is what I was getting in my post. For us big guys, the combination of the dw link, with a relatively high leverage ratio, and a crappy fox shox, results in a pretty saggy and sloppy ride.
    I appreciate all your input. Haven't had time yet to respond to everything stated. I am very curious about the rear shock and am open to changing it if there is a better option.
    At your size, you might want to try a lower volume air canister for the shock. It's about a $60 experiment, and takes about 5 minutes to install, with no special tools or mechanical aptitude required.
    Reputation: Foxbat's Avatar
    Feb 2006
    I agree with others that you might be riding too far into the mid stroke of your shock. If anything, DW-Link linkages are known to be more progressive and ride higher in their travel.
    parts leftover
    Reputation: schlim's Avatar
    Flux pedal strike.
    If you aren't already riding a 120mm fork, that will make a difference. Otherwise, try a low volume air sleeve as Kosmo suggested and/or PUSH tuning to keep the shock from blowing through as much travel.
    Quote Originally Posted by Foxbat View Post
    That was the rumors and maybe the case for some, but for bigger guys, the stock RP23 does not offer much support.
    Crazed Country Rebel
    Reputation: iheartbicycles's Avatar
    Pedal strike.
    Low bottom brackets rule. But you gotta know how to ride them.
    Stupid, but sometimes witty. Occasionally brilliant. Slow and fat though.
    Mike Vandeman Sucks Dong
    Dec 2004
    650B front, largest volume rear tire you can get, an extra 10 psi in shock. And if you still need more, put on 170 mm cranks. All the tricks I did and now am satisfied. I ride a lot of rocks, roots and off camber.
    Aug 2013
    Wait a minute, a 650b up front on a Flux? Is that legal? BUt seriously, that does sound cool. I am wondering if I can fit a 650b wheel and tire in the Fox 26" specific fork. If so, I am definitely giving this combo a try for the moto feel. I am in the process of trying to track a rocker for my flux and will do this if I can get one.
    Never heard of this... thanks for mentioning.
    Dec 2004
    Flux pedal strike.
    Most fox forks take 650b no problem.
  1. Pedal strike is Killing me!
    By OllieQ in forum Beginner's Corner
    Last Post: 06-25-2013, 12:24 PM
  2. Hard pedal strike CRACKS!! 575 2008
    By TRAIL CRANKER in forum Yeti
    Last Post: 08-04-2012, 09:28 AM
  3. AC & Pedal Strike - Afflicted ?
    By The_Lecht_Rocks in forum Nicolai
    Last Post: 04-26-2011, 09:13 PM
  4. 29ers and pedal strike?
    By IvanDobski in forum 29er Bikes
    Last Post: 03-28-2011, 03:31 AM
  5. Pedal Strike on Fixed?
    By Punch and Bebe in forum Singlespeed
    Last Post: 03-23-2011, 10:04 AM
