Results 1 to 2 of 2
    fried stuff with cheese
    Reputation: Locotiki's Avatar
    Feb 2005
    Few rear shock questions..i.e. PUSH.
    I've called Push to have some questions answered but now I have more and I'm having a hard time getting through to Push now so I thought I would post here.
    I'm going to buy the new Push rockers after much deliberation. I'm going to Push my stock RP3 when I buy the rockers as well. My question is what would the high volume air can do for me if I added that? If I'm spending that much money should I just get an RP23? I've done some searches and read a ton of good info but nothing really making it clear for me.
    Egg
    Amphibious Technologies
    Reputation: SCUBAPRO's Avatar
    Quote Originally Posted by Locotiki
    I may be wrong but the rockers are supposed to give you a linear mid stroke so no need for a bigger air canister. The RP3 will be fine as internals for both will be the same once PUSH'd, unless you really want the on-off switch on the RP23. You already have the off (-PP) position and fully on (+PP) so no real need for the RP23.
    "The best you've ridden is the best you know" - Paul Thede, Race Tech
