Results 1 to 6 of 6
Thread: a few questions
    a few questions
    does anyone know what make not grade of aluminium the tubesets are on a 5 spot ? where the machined parts are made ? are they still welded in the usa ?
    MK_
    MK_ is online now
    carpe maņana
    Reputation: MK_'s Avatar
    Quote Originally Posted by klimt
    They're made by SAPA in Portland, OR, if memory serves me right. All the welding and machining is done there. Not sure of what make the tubing is, however.
    _MK
    Before you diagnose yourself with depression or low self-esteem, first make sure that you are not just surrounded by a*holes
    Worth
    The Pack top and down tube is made by Worth in Tennesee. The seat tube and stays are done in Oregon by SAPA, then welded by SAPA. Heat treated machined
    DT
    Quote Originally Posted by turnerbikes
    DT
    is that the same for the 5 spot ?
    Tubes
    All of the tubing except the Highline top and down and the Pack top and down are made by SAPA. They have drawing machines, but not for the rad shapes like the pack and hiline.
    thanks
