Results 1 to 7 of 7
    Let's Ride!
    Reputation: digthemlows's Avatar
    Feb 2012
    Eyelet Bushings for Monarch Rt3 Plus for 08RFX??
    I don't think I'm putting in the right keywords for searching......I bought a RockShox Monarch RT3 Plus that came without bushings in the shock eyelets .... I wan't to keep my bushings in my Fox Rc4 coil just in case.........so, where do I order, and how do I know what size I need?
    Master of Nothing, but dammit if I don't try..............
    Team Blindspot
    Reputation: S-Works's Avatar
    Push Industries will have what you need.
    Astigmatic Visionary
    Let's Ride!
    Feb 2012
    There's nothing on the site, and again, what exactly is it that I need?? The bolts are 9mm for the shocks right??
    Let's Ride!
    Feb 2012
    MK_
    MK_ is online now
    carpe maņana
    Reputation: MK_'s Avatar
    What you're after is called reducers. Shock eyelet reducers.
    If memory serves me right, Turner uses 21.8mm x 6mm reducers. 21.8mm being their width and 6mm being the size of the hole for the bolt.
    _MK
    Before you diagnose yourself with depression or low self-esteem, first make sure that you are not just surrounded by a*holes
    MK_
    MK_ is online now
    carpe maņana
    You can use hardware for RockShox or any other brand which uses 1/2in eyelet or 12.7mm.
    This will work: Universal Cycles -- Rock Shox Monarch/Vivid/Ario 3.2 Mount Kits
    M6 x 21.8mm
    _MK
    Let's Ride!
    Feb 2012
    Thanks, I ordered 2...............
  1. Eyelet and Bushing question
    By Dirtman in forum Downhill - Freeride
    Last Post: 01-26-2013, 06:35 PM
  2. Eyelet Bushings
    By rlouder in forum Shocks and Suspension
    Last Post: 10-17-2012, 04:09 PM
  3. Fox Vanilla RC eyelet crack
    By eluv in forum Shocks and Suspension
    Last Post: 08-06-2011, 03:01 PM
  4. Fox Shox eyelet size question
    By Karve in forum Shocks and Suspension
    Last Post: 03-30-2011, 02:22 PM
  5. Broken eyelet/riv-nut in seatstay
    By jdmckeel in forum Frame Building
    Last Post: 03-10-2011, 06:39 PM
