Results 1 to 10 of 10
    DW chain stay protectors.
    Is anyone using a Chain stay protector on the new Turners? If so what are you using.
    I've not needed one....
    I have not noticed a single case of chain slap so far on my Large DW Spot. But I'm running a relatively tight chain with a medium cage rear mech, which helps.
    Compared to my HL Spot, which suffered constant noise in the rough stuff, the DW has been a revelation.
    If you need to fit one the tricky bits will be the chain/seat stay interface, and whether you go under or over the cable.
    jrm
    jrm is offline
    Reputation: jrm's Avatar
    Left over bar wrap
    Quote Originally Posted by C & D's Dad
    and electrical tape. Works great.
    cloth
    I like cheap cloth road bar tape. I use a dot of silicone under the last inch to glue it down. Lasts for years.
    DT
    Reputation: inkpad's Avatar
    I've been wrapping all my frames with a silicone, self adhering plumbers tape, works awesome & conforms to any curve, shape, etc..., looks sweet when applied carefully (like road bar tape, tennis racket grip, etc).
    http://www.rescuetape.com/?gclid=CPv...FRk_awodHUCOnQ
    Also, velcro (the fuzzy side) with adhesive works great & helps eliminate any chain noise. I use the velcro primarily for the DH bike. It doesn't wrap or conform very well, but is great for straight areas (I use the 2" wide roll).
    Quote Originally Posted by turnerbikes
    DT
    Thanks Dave,
    Is it possible to get a couple of pictures ?
    Reputation: Copenhagen's Avatar
    Nov 2007
    old tube
    C&D, I wrapped mine in a sliced up old tube - seems to work fine for the little bit of chain slap I sometimes get.
    ride
    Reputation: ignazjr's Avatar
    second on the cloth bar tape
    I'll second cloth bar tape. You have to wrap it really, really tight. I close it off with black tape on either end. Here's a pic of my old Croll steel hardtail with a cloth bartape cstay protector. I built this bike in Oct of '97 and have never changed the tape...
    Redstone Cyclery
    intense*transition*rocky mountain*turner
    web - tweet - FB
    Lyons, CO
    NMBP
    I use tennis racket grip tape on my chainstay with a couple of zipties on either end to keep it secure. Seems to work well and looks good since they come in colors. Easy to keep clean also.
    I think I need to Upgrade
    Reputation: AzSpeedfreek's Avatar
    I prefer Hockey tape. It is durable, looks good and is cheap at $2 a roll.
